ᐅ Kallax doors installed too deep – how to remove them again?
Created on: 5 Oct 2015 08:17
V
velimir
Hello everyone, I recently fitted an Ikea Kallax shelving unit with matching doors. However, I have noticed that the doors were mounted too deep, meaning they sit much lower in the frame and do not align flush with the top edge of the shelving unit. This not only looks unattractive but also makes operation more difficult because they catch on the bottom edge.
Now my actual question: How can I remove the doors from a Kallax unit if they have been installed too deep? Do I need to dismantle the hinges, or is there a trick to take the doors off without damaging the entire structure? I would really appreciate any tips, experiences, or a step-by-step guide!
V
velimir
7 Oct 2015 11:58
Great, thank you very much for the detailed advice!
I will remove the door and then reinstall and adjust it very carefully, as you described.
I will get back to you if I have more questions or can provide an update.
V
vinli
7 Oct 2015 12:10
Sure. If you are looking for adjustment instructions, Ikea often provides PDFs that explain this in detail. Otherwise, in short: Turn the adjustment screws on the hinge plate until the door is properly aligned. Done.
V
velimir
8 Oct 2015 09:14
Update from me: Yesterday, I removed the doors by lifting them up and carefully pulling them out. It worked surprisingly well. Then I loosened the hinges on the panel, repositioned the door, and fine-tuned it with the adjustment screws.
Result: The doors now fit much better – flush and without sticking. Thanks to everyone for the support!
