I’m facing an issue with my new KALLAX shelves from IKEA, specifically with the doors. During assembly and placement, I noticed that the doors hit the baseboards on the wall as soon as I open them. The shelf is placed directly against the wall, and the doors seem either too wide or don’t extend far enough to overlap the baseboards.
Since I prefer not to remove the baseboards or alter the entire wall covering, I’m wondering if anyone has experience with this or knows possible solutions to avoid this problem. Maybe there are alternative door hinges, special spacing options for installation, or other tricks I haven’t thought of yet.
I would appreciate well-informed tips that also include a brief explanation of how they can be implemented. Thanks in advance!
Hello Gilo39,
Your issue with the KALLAX doors and the baseboards is a common challenge when installing furniture against walls with fixed skirting boards. Here are some suggestions for possible solutions:
1. Distance from the wall: Often, simply moving the shelf slightly away from the wall is enough to free the door’s swing path. A gap of 1-2 cm (0.4-0.8 inches) can make a big difference, especially if the hinges are not perfectly flush with the back panel.
2. Adjust door stops or replace hinges: Many hinges (especially IKEA’s own) are either not depth-adjustable or have an excessive offset. There are special flap door hinges with shorter stops that allow the door to sit further forward. You may need to adjust the drill holes accordingly.
3. Modify the baseboards: If the shelf is fixed in place anyway, it’s possible to chamfer the skirting boards at the affected spots using a router, so the door can pass without removing the entire baseboard. This is a clean and often inconspicuous solution.
4. Alternatively: Consider mounting swing doors that protrude less at 90 degrees or look into sliding doors.
My question for you is how much space you currently have between the shelf and the wall, and which exact model version of the KALLAX doors you are using. This will help to better assess what is technically feasible.
Best regards, kulau
Best regards, kulau
kulau schrieb:
1-2 cm can work wondersThat’s absolutely true! Often you think you need to renovate everything, but sometimes a small trick is enough. I just stuck thin felt strips to the back of my door, so it sits slightly further away from the skirting board. You can hardly see it, the spacing is right, and the doors open easily. 🙂
Also, a self-adhesive door stopper can help prevent the door from banging against the skirting board.
Sometimes a combination of a minimal gap between the wall and door along with padding does the trick. Good luck!
There are clear technical key points:
- Standard KALLAX doors are usually designed to be flush with the front edges of the shelves. The hinges offer limited adjustment in depth, typically no more than 4-5 mm (0.16-0.20 inches).
- Baseboards typically protrude about 18-22 mm (0.7-0.87 inches) from the wall surface. To avoid collisions, the cabinet should be positioned offset from the wall by approximately this amount.
- Adjusting the baseboard by beveling it with a router attachment is a solid solution that provides lasting additional space without risking instability.
- Another option is to use special hinges with adjustable flaps to bring the door closer to the cabinet. However, this may require extra effort for drilling.
Recommendation: If there is limited space for placement, adjusting the baseboards with the appropriate technique is the most reliable solution.
Paxton38 schrieb:
The standard KALLAX doors are designed to align flush with the front edges of the shelves. The hinges have limited adjustability in depth, usually no more than 4-5 mm (0.15-0.2 inches).Thanks for the technical assessment.
Currently, there is almost no gap between the back of the shelf and the wall – the shelf is placed directly against the wall. The baseboards are about 20 mm (0.8 inches) high and approximately 12 mm (0.5 inches) deep. The doors hit or get stuck when I try to open them.
vin_leo schrieb:
I simply attached thin felt strips to the back of the door Sounds like a good idea, but I’m concerned that it might not be enough if the door actually hits the baseboard directly.What do you think about special hinges? Would new holes need to be drilled? And can the original screws be reused, or would a completely new mounting plate be required?
For me, practical and not too complicated solutions are most important, as I prefer not to do too much DIY work.
