ᐅ KALLAX Doors Are Misaligned When Opening – Installation Error?
Created on: 28 Jul 2021 18:43
Sego1
Sego1
28 Jul 2021 18:43
Hello everyone, I installed the doors on my KALLAX shelving unit, but I’m having an issue where they don’t open smoothly. They seem to catch or rub slightly against the frame. I’m not sure if this is due to an installation error or if it’s normal for KALLAX doors, as I followed the instructions carefully.
Could it be that the hinges or mounting points are misaligned? Or is the problem possibly with the door itself, such as its fit? I would appreciate your opinions and advice on how to fix this issue. Thanks in advance!
RICCARDO
28 Jul 2021 19:12
If the doors stick or rub, first check whether the hinges are properly tightened. Often, a minor adjustment is enough by slowly loosening the screws in the hinges and rehanging the door.
The edges need to be parallel to the frame; otherwise, it will jam. Also, check if the door itself is warped.
Grace
29 Jul 2021 07:51
Hello Sego1, the “binding” issue you described with the KALLAX doors can have several causes.
First, it’s important to know that the hinges on KALLAX doors are individually adjustable. Small screws on the hinge allow you to adjust the alignment in depth, height, and width.
Sego1 schrieb:
They seem to stick slightly or rub against the frame. I’m not sure if this is a mounting error or if it’s normal for KALLAX doors, as I followed the instructions carefully.
The simplest approach is to open the doors, slightly loosen the screws on the hinges, and adjust the door so that it sits evenly and opens easily. Sometimes there are stresses in the material, especially if the doors or the shelving unit have been stored in a damp environment.
Another point is that with some KALLAX shelving units, the dimensions can vary slightly – here, alignment and adjustment help. If the door is really warped or damaged, you should consider replacing it.
In general, mounting errors are not very common with this system, but even the smallest inaccuracies can cause the problems you described. I hope this helps!
Lis53
30 Jul 2021 10:04
In addition to what has already been mentioned, I would like to add the following:
The KALLAX doors are designed to allow for some adjustment during installation to enable individual fine-tuning. However, it is crucial that the attachment points at the hinges and the shelving unit are properly aligned. Installation errors often manifest exactly as described – a door that “guides” when opening, meaning it does not move smoothly and freely.
Please ensure that:
- The hinges are firmly secured, but not too tight.
- The door does not rest on the floor or on the shelf.
- The adjustment screws (usually 3 per hinge) are correctly installed and used to optimize alignment vertically, horizontally, and in depth.
It may also be helpful to use a spirit level to check whether the KALLAX shelving unit itself is straight and not warped. A slightly crooked piece of furniture can also cause these problems.
In conclusion: if there are no visible damages, it is usually the case that adjusting the hinges allows the doors to operate as desired.
