ᐅ KALLAX doors swell after exposure to moisture – could there be an underlying cause?
Created on: 15 Sep 2020 10:12
Kinke3
Kinke3
15 Sep 2020 10:12
I have an issue with my IKEA KALLAX shelving units, specifically with the installed doors. After more humid weather or when airing out the room, the doors no longer open or close properly. It feels as if they are catching on the cabinet walls or the hinges.
I suspect that moisture in the wood or particleboard causes the material to swell, which in turn blocks the doors. Has anyone experienced this behavior? Is there a permanent solution to prevent the KALLAX doors from sticking when humidity levels are higher?
I’ve also considered whether the material can be treated somehow, or if this is a design-related issue that is difficult to avoid.
I would appreciate any advice, tips, or well-founded guesses!
Josan
15 Sep 2020 10:45
Kinke3 schrieb:
it feels like they are getting stuck somewhere on the cabinet walls or the hinges
Hello Kinke3,
you described the issue with the KALLAX doors very well. The shelving unit is actually made from wood-based panels like MDF or particle board, which tend to swell when exposed to moisture. This often causes exactly the kind of problems where doors catch on the hinges or the surrounding cabinet frame.
A short-term fix is often to remove the doors slightly and gently sand or deburr the edges, especially the spots where the door sticks.
In the long run, maintaining a consistent indoor humidity level helps a lot. If possible, sealing the edges with clear varnish or wood oil can reduce swelling.
It is also important to ensure the doors are properly adjusted – often just a small turn of the hinge screws can help the door sit better and prevent it from binding.
If you want, I can send you a brief guide on adjusting KALLAX doors.
KIN42
15 Sep 2020 11:28
In my experience, the issue with KALLAX doors is actually closely related to the material.
Particleboard and MDF have a certain hygroscopic property and absorb moisture from the air—especially if the surfaces are untreated or only minimally sealed. This leads to swelling, as you correctly suspected.
Additionally, storage and location play a role: in rooms with high humidity or close to heat sources, the problem can become more pronounced.
One possible solution is to protect the doors with water-repellent paints or films that repel moisture. Alternatively, placing a small dehumidifier in the room can help reduce the relative humidity and minimize swelling.
LIELCHEN
15 Sep 2020 14:07
Josan schrieb:
In the long term, maintaining a consistent indoor humidity and, if possible, sealing the edges with clear varnish or wood oil helps most
Honestly, I’m not convinced by the usual recommendation to fix this issue with clear varnish. It only treats the wood unnaturally, making it more sealed rather than breathable.
I wonder whether this KALLAX system has a fundamental design flaw if wooden composite doors regularly swell and stick under normal climate fluctuations. Wouldn’t it make more sense to generally use different materials or to design the entire hinge and door system to be less susceptible to swelling?
I have often noticed that many people here only address the symptoms rather than the cause. Instead, one might consider whether KALLAX shelves with metal or plastic doors could be a better option—at least in situations where moisture is a concern.
What do you think?
TYRELL
15 Sep 2020 18:34
LIELCHEN schrieb:
whether this KALLAX system has a fundamental design weakness
The KALLAX shelving unit is originally designed as a modular system with open compartments, and the doors are an add-on feature. The MDF or particleboard panels used, combined with a thin foil coating, represent a cost-effective solution rather than a high-quality solid wood option.
From a technical standpoint, the issue is that the doors do not have a full-surface seal, especially the edges, which are often only coated with foil and are not truly water-resistant. This allows atmospheric moisture to penetrate relatively easily, causing swelling.
The space between the door and the carcass is quite tight with the KALLAX hinges. When the material swells, even millimeters can be enough to cause the doors to stick.
For a long-term solution, I recommend:
1) Checking and, if necessary, adjusting the door hinges (there are usually 2-3 adjustment options)
2) Sanding the resting edges of the doors by about 0.5 mm (0.02 inches) to allow enough clearance
3) Installing seals or small felt pads at critical contact points to reduce friction
4) Treating the edges with wood protective varnish (at least 2 thin coats)
Together, these steps can provide noticeable improvement. I would also first check the indoor humidity and, if necessary, control it with ventilation or a dehumidifier. This is especially important in humid rooms such as kitchens or bathrooms.
Is the KALLAX shelf installed in a room with normal humidity, or rooms exposed to moisture?
Kinke3
16 Sep 2020 09:22
TYRELL schrieb:
Is your KALLAX shelf placed in a room with normal humidity, or in rooms that get exposed to moisture?\
Thank you for the detailed response, TYRELL. The shelf is located in my living-dining area, which is usually a fairly stable environment. However, we’ve had quite high humidity levels over the past few weeks, sometimes around 70-80% during the day.
The doors tend to stick, especially after days with higher humidity peaks, but it usually normalizes a bit afterward.
The idea of using small felt pads sounds promising—I haven’t tried that yet and it could definitely reduce the friction.
I will also check the edges of the doors and carefully sand them down a bit. I’m a bit unsure about applying a wood protective finish though, since the doors are coated in color and I’m not sure I’ll be able to do it without affecting the appearance.
Regarding the hinge adjustment: How exactly does that work with the KALLAX? Is there a step-by-step guide I can follow? How much play should I allow at most, so the doors don’t feel too loose but also don’t get stuck?
