ᐅ KALLAX Door Magnetic Catch Too Weak – How to Upgrade It?
Created on: 10 May 2024 14:23
LIFRA57
LIFRA57
10 May 2024 14:23
I installed the original magnetic catches on the doors of my IKEA KALLAX shelving unit. Unfortunately, I’ve noticed that over time these magnetic catches have become too weak, so the doors no longer close properly and mostly just hang loosely. The original design seems simple and maybe intended for light use only.
Now I’m looking for a practical solution to retrofit or reinforce the magnetic catch without significantly altering the appearance or function of the unit. Has anyone had experience with replacement magnets or alternative mechanisms that have proven effective? I’m especially interested in whether strong neodymium magnets can be used directly or if there are better systems specifically designed for furniture. Also: What is the best method to attach stronger magnets to prevent slipping or damage?
I’m looking forward to your tips and experiences!
SONLIS
10 May 2024 15:12
LIFRA57 schrieb:
Has anyone had experience with replacement magnets or alternative mechanisms that have proven reliable? I’m especially interested in whether strong neodymium magnets can be easily used or if there are better systems suitable for furniture.
Neodymium magnets are generally a good choice, provided they are properly installed. It is important that they are not glued directly onto the wood surface but instead set into specially milled recesses to withstand stress and prevent slipping. Alternatively, small door spring mechanisms placed under the door frame are also a reliable option.
Another tip: make sure the counterpart (the metal plate) is properly mounted so that the strong magnetic force is not reduced by misaligned contact surfaces.
KNUTGI
10 May 2024 16:07
SONLIS schrieb:
Neodymium magnets are generally a good choice, as long as they are properly attached.
😊 Exactly! For my KALLAX, I simply used flatter but much stronger magnets and fixed them with thin double-sided tape. That holds really well and looks almost like the original. If you want something more secure, small screw-in magnets are a good option – they practically last forever.
LIFRA57 schrieb:
What is the best way to attach the stronger magnets so they don’t slip or cause damage?
I recommend lightly sanding the surface first with fine sandpaper, then using a strong assembly adhesive. That way, nothing will slip. Also, with stronger magnets, plastic covers are advisable if the doors are made from thinner material to prevent chipping.
Jukin
11 May 2024 09:18
Hello LIFRA57,
I can definitely understand the issues with KALLAX door magnetic catches. IKEA often opts for a simple solution that looks discreet but doesn’t necessarily provide long-lasting stability.
For retrofitting with neodymium magnets, I recommend first removing or at least replacing the original magnet holder. Neodymium magnets are much stronger and, if mounted too close to each other or directly on the surface, can damage the material over time.
Sometimes it also comes down to correct positioning: the magnets must align precisely opposite each other, otherwise they lose strength. I’ve seen quite a few installed at mid-height or offset, which significantly reduces their holding power.
In summary: stronger magnets are fine, but they need to be fitted carefully and securely first. Alternatively, you can also install locking mechanisms like small latches that are barely visible but provide stronger holding.
GALEO4
11 May 2024 20:34
LIFRA57 schrieb:
Does anyone have experience with replacement magnets or alternative mechanisms that have proven reliable?
The problem with IKEA magnetic catches is simply that they are designed with minimal strength. If you use stronger magnets, the wooden doors tend to snap shut every time they close, which puts stress on the hinges and can eventually warp the material.
So if you want a truly durable solution, you should consider alternative closing methods, such as push-to-open catches or small drawer latches. These are more visible but provide much stronger retention.
Jukin schrieb:
Alternatively, you can install locking mechanisms like small latches
Exactly, that’s where I would focus. Much stronger magnets often cause more problems than they solve. And honestly, isn’t it a bit convenient to rely on the magnet to do the work? Sometimes it’s worth putting in a little extra manual effort.
