ᐅ Kallax door hinge not working after repainting the wall – what could be the reason?
Created on: 23 Mar 2021 07:43
Anjeko
Anjeko
23 Mar 2021 07:43
I recently repainted my wall using a water-based latex paint, which has a slightly glossier finish compared to the previous matte paint. Since then, the door hanging system of my Kallax shelf door hasn’t been working properly – the door sticks and is very difficult to move. Before painting, everything operated smoothly.
My question is: what could cause the new wall paint to affect the door hanging mechanism? Could it be an issue with adhesion, or does the paint change the friction? Are there any known interactions between latex paint and the Kallax metal tracks? I look forward to your experiences and helpful advice!
barle
23 Mar 2021 08:12
The problem usually occurs because the paint was applied too thickly, which narrows the guide channels of the door suspension. Simply clear the grooves or carefully sand them down.
lomin
23 Mar 2021 08:45
That sounds frustrating – especially when something changes so suddenly after a seemingly harmless step like painting! I once experienced something similar; in my case, the paint itself created a kind of sticky surface that prevented the door from moving smoothly. Maybe it would help to lightly sand the areas where the door makes contact or treat them with some silicone spray?
cassandra
23 Mar 2021 09:17
It is known that latex paints form a somewhat more durable and often glossy layer after drying, which adheres well mainly on the surface. If the paint has gotten directly onto the metal parts of the door hinges, it can negatively affect their movement due to increased friction. I recommend carefully removing all paint residues from metal guides and contact surfaces, if necessary using fine sandpaper, and then applying a light lubricant (e.g., silicone spray).
karbar
23 Mar 2021 09:45
Correct, the paint often narrows the guide rails. You should carefully sand them down and then clean the guides. Usually, that is enough.
Anjeko
23 Mar 2021 10:10
barle schrieb:
The problem is usually caused by applying the paint too thickly, which narrows the guide tracks of the door suspension.
Thanks for the tip. I applied the paint with a small foam roller in several thin layers – still, the result was noticeably glossier and seemingly harder than before.
lomin schrieb:
I had a similar issue once; in my case, the paint itself created a kind of sticky surface.
That could also be the case, since in some spots the door feels slightly rough.
cassandra schrieb:
I recommend thoroughly removing all paint residues from the metal guides and contact surfaces, if necessary using fine sandpaper, and then applying a light lubricant (e.g., silicone spray).
I’ll try that this evening. Is there anything specific I should avoid when using latex paint to prevent further damage to the mechanism?
