Hello everyone, I have a problem with my IKEA Kallax shelves that I have fitted with doors. The door cutouts, meaning the recessed areas in the carcasses, are crumbling badly, especially around the edges. This makes installing the doors difficult because the stability is compromised and the screws barely hold. I suspect the material there is quite thin, but without these cutouts nothing fits. Has anyone had experience with how to effectively reinforce these chips or weak areas? Possible solutions could be reinforcements or special techniques that secure the area without significantly altering the furniture. I would appreciate tips on this topic, especially practical materials or methods suitable for Kallax. Thanks in advance!
JEREMIAH3826 Feb 2022 20:53Hey Suzan, I completely understand how frustrating that is! Especially with Kallax, those cutouts are quite tricky since the panel material is often not very solid.
I had similar problems when I installed my doors – the edges crumbled, and the screws didn’t hold properly anymore. What worked for me was to coat the edges with wood glue and then press in small wooden splinters or wood chips as filler material. After it dried, I sanded it again and then installed the screws. This significantly improved the stability for me.
Maybe this could be an option for you as well? I know it sounds a bit makeshift at first, but often these kinds of solutions help before going for more complicated reinforcements.
Hang in there, this can be frustrating, but with some patience, you can definitely manage it! 🙂
JEREMIAH38 schrieb:
Applying wood glue and then pressing small splinters or wood chips into it, basically as a filler.That sounds reasonable in principle, but I wonder if it will hold up long-term. The pressure exerted by the doors could loosen the filler again and cause repeated breakage.
Another option would be to use glued wood strips as reinforcement along the routed-out areas, fixing them from the inside with wood glue and screws. This could significantly increase stability because it reinforces the thin material rather than just filling it.
Alternatively, you could consider special repair fillers or epoxy resins, which are harder and more durable. I have read about these in several furniture repair forums.
Suzan, how deep and wide are the affected routed-out areas exactly? That would help to recommend the appropriate approach.
Hello Suzan, here is a brief guide for stabilizing Kallax door cutouts that are crumbling:
1. Preparation: First, remove all loose parts and debris with a vacuum cleaner. Then lightly sand the edges to ensure better adhesion.
2. Filler material: Use high-quality wood filler or an epoxy-based repair filler. Apply it thickly to the crumbling areas and reshape the cutouts smoothly.
3. Reinforcement: Once the filler has cured, you can glue strong wooden strips (e.g., pine strips 10x10 mm (0.4x0.4 inches)) along the cutouts and secure them from the inside with short screws. Make sure the screws are not visible from the front side.
4. Finishing: Lightly sand everything again, level out any unevenness, and then seal with a suitable paint or varnish.
Important: Please do not use screws that are too small, as they quickly lose grip in the soft panel material. If screw connections inside the cutout are necessary, countersunk screws are recommended to avoid further splitting of the material.
This combination worked well for me; the doors remain stable afterward, and the cutouts are largely secured.
Feel free to reach out if you need more details or support with any of the steps.
