Hello everyone, I have a problem with my Kallax shelving unit from Ikea. Unfortunately, I made a mistake while cleaning: I probably used an unsuitable cleaning agent, most likely one that was too harsh and/or not suitable for wood veneers. Now there are several dull discolorations and some areas where the surface feels slightly roughened. I’m not sure if it’s just surface damage or if the material has been penetrated. My question is: How can I best restore a Kallax shelving unit that has been damaged this way by using the wrong cleaning products? Are there any recommended repair or restoration methods to visually improve or completely fix the surface? What approach has worked well for you when laminate or coated surfaces have been dulled or affected? I’m hoping for detailed tips—thanks in advance!
Heleneix58 schrieb:
Does anyone have experience whether Ikea offers cleaners or care products suitable for Kallax?Ikea recommends simply cleaning Kallax with a mild, water-based detergent, preferably just dish soap in warm water. I am not aware of any special Ikea cleaners specifically for Kallax – most people use general-purpose cleaners designed for coated furniture. The ingredients are usually mild, but please avoid solvents or abrasive cleaners.
Heleneix58 schrieb:
Should I seal the repaired area afterwards, or is the impregnation from the repair kit sufficient?The impregnation or sealing is generally covered by the repair kit, which applies wax or varnish. An additional clear coat can help but also requires more effort and may be noticeable visually. So if you use a good repair kit and follow the instructions carefully, that should be enough.
Good luck with the repair, and feel free to ask more questions!
barEsperan4 Dec 2015 09:49Ikea does not sell special cleaners for Kallax; dish soap is sufficient. No additional sealing is necessary after the repair.
Heleneix585 Dec 2015 15:28Update: I tried the laminate repair kit and carefully touched up the affected areas. The whole thing looks much better now. The dull roughness is almost gone, and the color matches well. Thanks for the tip!
In the future, I will be much more cautious with cleaning agents and only use mild products. For anyone facing similar issues: don’t give up too soon, with patience and the right repair kit, a lot can be saved 🙂
