ᐅ Kallax crumbling after years in the basement – is moisture storage to blame?
Created on: 17 Jun 2021 09:37
martyn
martyn
17 Jun 2021 09:37
I have a Kallax shelf unit that I bought new about 4 years ago. Unfortunately, I had to store it in my basement for an extended period, roughly over 2 years. Now that I’m using it again, I’ve noticed that the material is quite crumbly and brittle in some areas. I suspect that the damp storage conditions in the basement might be the cause, as the humidity there is often high.
My question for you: Can moisture in the basement actually cause the MDF wood of the Kallax shelf to deteriorate, become brittle, or even crumble? Has anyone had similar experiences or can explain how moisture affects this kind of furniture? Is there any treatment or repair method that could restore the material’s durability?
I’m looking forward to your expert opinions and advice!
KAUDRA62
17 Jun 2021 11:29
martyn schrieb:
Can moisture in the basement really cause the MDF wood of the Kallax shelf to deteriorate, become brittle, or even crumble?
Hello martyn, yes, moisture definitely plays a role here! MDF does not like water; it soaks it up, causing swelling and eventually a crumbly texture—almost like the board has been dancing around with wet feet. 🙂
Basements are often more humid in both summer and winter compared to regular living areas, which creates a perfect environment for such wear and tear. If the shelf has been in that kind of environment for a long time, the material can suffer quite a bit.
For repair: If you’re lucky, you can gently sand down the crumbly spots and smooth them out with wood filler or special MDF putty. The important thing is to keep the shelf stored in a dry place afterward and, if needed, treat it with a sealant or lacquer.
So, moisture is usually the culprit, but with a little care (and time), you can sometimes bring furniture back to life! 😉
Juan31
17 Jun 2021 13:57
Damp conditions are generally harmful to MDF boards, like those used in Kallax units. MDF is made from compressed wood fibers with a binder that swells and loses its structural integrity when exposed to moisture over time.
The material tends to degrade, stability decreases, and the surface can become crumbly due to swelling. Storing it in a damp basement for years is very likely the cause of this damage.
Regarding repair: most of the damage is irreversible because the material has swollen. Small areas can be treated by sanding and sealing. However, complete restoration is rarely possible. To prevent damage, the shelf should be kept in dry, well-ventilated spaces whenever possible.
In summary, moisture is the main reason for the crumbly surface on your Kallax shelf.
Hannes
17 Jun 2021 14:12
Juan31 schrieb:
Moist conditions are generally harmful to MDF boards
Exactly. Moisture reduces the strength of MDF.
It is best to store them dry immediately. Repair is usually complicated.
KAUDRA62
18 Jun 2021 08:44
Juan31 schrieb:
Regarding the repair: Most of the time, the damage is irreversible because the material has swollen.
Unfortunately, that is often true. Still, it’s worth not losing hope entirely. If you want to restore the shelf’s appearance, I would definitely start by sanding the crumbling edges with fine-grit sandpaper and then use an MDF filler. After that, apply a primer and a water-resistant paint or lacquer.
If your main concern is stability, replacement is usually the only option. But if the Kallax is just holding items that aren’t too heavy, this kind of treatment can still make a big difference.
If moisture reached inside, the glue might have loosened, so I’d carefully check the condition by applying some pressure.
A basement is simply no comfort zone for chipboard – we all notice that here again and again! 😉
