ᐅ KALLAX surface peeling after furniture cleaner – how to reattach like new?
Created on: 17 Jun 2024 18:37
du_fu61Hello everyone,
I have a problem with the surface of my Ikea KALLAX shelf after cleaning it recently with a common furniture cleaner. The thin melamine or plastic coating on the shelves has started to lift or peel in several spots. Now my question is: what is the best way to reattach this coating so that it stays like new and doesn’t swell or peel off again?
Are there any specific adhesives you would recommend? Should I prepare or clean the surface in any special way before reapplying the coating? Or are there better methods than gluing that offer a more durable result? I definitely want to avoid what happens to many people – the coating coming off again after just a few weeks.
Thanks in advance for your tips and experiences!
warrenka5718 Jun 2024 09:17du_fu61 schrieb:
How can I best reattach this covering so that it holds like new and doesn’t swell or peel off again?I know that all too well, it’s really frustrating!
I would advise you to proceed very carefully. It’s important that the surface is dry and clean, otherwise nothing will stick properly.
Leote schrieb:
Before gluing, make sure everything is free of grease, preferably clean with isopropanol. I can only agree with that.From my own experience, a two-component adhesive for wood/plastic worked well, even though it’s a bit labor-intensive. A small tip: lightly sand the covering beforehand so the glue can adhere better. But be gentle, don’t sand too much or you’ll damage the covering.
Don’t despair, it will work out! 🙂
warrenka57 schrieb:
Lightly sand the surface beforehand so the adhesive can bond better.That is correct; a slightly roughened surface significantly improves adhesion. I recommend using ultra-fine sandpaper with a grit of 320 to 400. Afterwards, the surface should be degreased with a lint-free cloth and isopropanol.
A clear polyurethane-based construction adhesive or a special contact adhesive for laminate/melamine works well as glue. Make sure the adhesive is waterproof, as furniture cleaners are often damp.
Avoid applying excessive pressure – an even pressing with a clean, weighted board for at least 24 hours is better.
For preparation: The area should be completely dry and clean, and any residues of old adhesive should be removed before reapplying, ideally by mechanical means such as sanding or scraping.
This way, you can achieve a durable bond. Feel free to ask if you want more details!
