ᐅ Is a Kallax shelf permanently damaged after multiple assemblies and disassemblies?
Created on: 26 Dec 2020 17:23
Sutau32Hello everyone,
I have a rather specific question for you: What happens to the IKEA Kallax shelving unit when it is assembled and disassembled multiple times? Specifically, I want to know if this shelf eventually becomes permanently worn out after repeated assembly and disassembly—that is, if its stability, fit, or overall durability significantly deteriorates—or if it is simply built robustly enough to handle this reasonably well.
I have already taken the shelf apart completely twice and rebuilt it in a different location, and I notice that some connections are no longer as tight as the first time. The edges appear slightly frayed, and the back panel no longer fits as snugly—I wonder if this is normal with frequent reassembly, or if this process accelerates the product’s lifecycle prematurely.
I am particularly interested in your experiences as well as any technical background you can provide regarding material fatigue, screw quality, and the overall construction. Thanks in advance for your insights!
Sutau32 schrieb:
whether this shelf will eventually be completely “worn out” after repeated assembly and disassembly, meaning the stability, fit, or overall durability suffers significantlyCome on, the Kallax is basically a pretty simple cube with sometimes fragile joints. Anyone seriously expecting the piece to still hold together like new after dozens of assembly and disassembly cycles is living in a dream world.
Basically, you can say that materials like particleboard or MDF that IKEA uses aren’t designed for frequent dismantling. Every time screws and dowels are loosened, it’s like pulling out small wood particles—and this adds up over time.
On top of that, the back panel is basically just thin chipboard, which can easily tear or warp after being removed several times. If you don’t take that into account, you basically ruin your shelf.
I think it’s not necessary to immediately shout “This thing is junk!” but realistically speaking: a Kallax is a piece of everyday furniture, not a professional shelf meant for constant dismantling.
cassandra26 Dec 2020 18:02I can contribute some technical details on this topic:
The Kallax shelf is mainly made of lacquered particleboard with a thin MDF back panel. These materials have moderate resistance to mechanical stress. When the unit is repeatedly assembled and disassembled, two main weak points tend to appear:
1. Screw hole brittleness: Particleboard and MDF tend to lose their grip on threaded holes after repeatedly removing and reinserting screws. This leads to loosening joints.
2. Dowel wear: The wooden dowels used to secure the joints can break or deform from frequent assembly and disassembly, which reduces the accuracy of the fit.
The thin back panel is also only fixed with small nails and quickly loses stability due to deformation, making the entire shelf less torsion-resistant.
Therefore, from a technical standpoint, it is correct that multiple disassemblies without special precautions negatively affect durability. If the shelf owner plans to modify the unit frequently, it is advisable to drill the screw holes larger and reinforce them with wood glue or use metal fasteners.
cassandra schrieb:
The thin back panel is only attached with small nails and quickly loses stability due to deformationExactly. I’d like to go into a bit more detail regarding the construction of the Kallax.
The carcass is made from laminated particleboard, usually about 12 mm (0.5 inches) thick – not exactly solid wood. The corner joints typically rely on a combination of wooden dowels and screws with a cam lock mechanism or simple screws. This provides sufficient stability for everyday use but is not designed for repeated disassembly and reassembly without extra precautions.
During disassembly, the screws tend to loosen from the pre-drilled holes, which offer limited grip in the particleboard material. This results in swollen and crumbly areas around the holes that cannot be fully restored even with thread locking compounds or glue.
The back panel, often a thin fiberboard fixed with nails, significantly contributes to the unit’s torsional rigidity. If it is removed more than once or twice, the smoothness of the side panels is often compromised, leading to a carcass that no longer closes precisely.
My advice: If you plan to disassemble the unit frequently, reinforce the holes with some wood glue and wooden dowels and handle the back panel carefully. If in doubt, you can also attach additional L-shaped metal corner braces to improve stability.
I’m curious how often and under what conditions the shelf has been moved already? Does the issue appear especially under heavier loads?
Sutau32 schrieb:
the edges look slightly worn, the back panel doesn’t fit as tightly anymoreThese damages are typical signs of material fatigue in the structure of the furniture, which inevitably occurs with repeated assembly and disassembly.
kulau schrieb:
If in doubt, you can also attach additional L-shaped metal angle reinforcements at the corners to increase stability.Honestly, anyone who does that completely misses the point of a Kallax :-)
Jokes aside – the Kallax is an affordable everyday shelf, not a designer or industrial-grade piece of furniture. Once you start messing around with angle braces and wood glue, you lose the flexibility the furniture promises and just shift the problem to how it looks. Sure, if it holds, it holds. But I think the real question is whether you should even keep using it after multiple moves.
The material is thin and delicate, and it’s not designed as a long-term, repeatedly disassembled solution. Personally, if you move frequently, I’d rather invest in sturdy crates or truly transport-friendly units.
You can make a lot out of a Kallax, but it’s definitely not a mobile long-term organizer meant for numerous disassemblies. 😉
