ᐅ KALLAX dividers are spreading apart – is a rebuild necessary?
Created on: 14 Aug 2022 18:07
annagla
annagla
14 Aug 2022 18:07
Some time ago, I assembled a KALLAX shelf unit, and although I was careful during assembly, I’ve noticed that the individual compartments start to spread apart after a while. This makes the shelf feel unstable, and the joints seem to loosen. My question is: do I need to completely rebuild the shelf to permanently fix this issue, or are there other tips or tricks to prevent the compartments from spreading without having to take everything apart?
I’m especially interested in whether it makes sense to use additional fixing materials, or if the problem usually stems from the initial assembly and cannot be resolved by simply adjusting it. Thanks in advance for your experiences and advice!
Ianlau
14 Aug 2022 19:34
Hello annagla,
I had a similar issue with my KALLAX shelf, so I’m happy to give you a more detailed response. Basically, the joints of the KALLAX tend to come apart if they are not properly aligned or if the dowels and screws are not tightened correctly.
Before you rebuild the entire shelf, I recommend the following steps:
1. First, check whether all screws and dowels are still firmly in place. Over time, they can loosen, especially if the shelf is moved or loaded.
2. If you notice that some connection points are already slightly damaged or warped, it might help to stabilize and re-secure those parts with a bit of wood glue.
3. If the problem persists, a complete rebuild might be useful, particularly if the shelf has been heavily used multiple times and the wood has lost its shape stability.
annagla schrieb:
…or are there any other tips or tricks to prevent the compartments from coming apart without having to disassemble everything?
Yes, sometimes minor adjustments and tightening the screws again are enough. Adding extra brackets or corner connectors on the back can also significantly improve stability. This often works well if the shelf is not meant to be visible.
However, if you plan to use the shelf heavily over a longer period, a full rebuild focusing carefully on alignment and the strength of the joints is worthwhile.
I hope this helps you for now! If you describe more precisely how the parts are coming apart, I can give you more specific advice.
JORGERON
15 Aug 2022 08:15
Ianlau schrieb:
Attaching additional brackets or corner connectors to the back can significantly increase stability.
I can only agree with that. The easiest way is to fix small metal brackets in the corners. This keeps the KALLAX unit together and prevents the compartments from coming apart.
Palenar
16 Aug 2022 13:52
I would like to add some technical details to the discussion, as the topic is more complex than it may seem at first glance.
KALLAX is a piece of furniture primarily made from medium-density fiberboard (MDF) with a decorative laminate finish. This material combination is lightweight and cost-effective, making the furniture attractive for versatile use. However, it does come with some limitations regarding the stability of joints and long-term load capacity.
Regarding the issue of the compartments coming apart:
Mechanical stresses occur at the joints due to changing loads (for example, when placing books or during transport). MDF tends to absorb moisture and swell slightly, which can affect the precision of the dowel connections. Another factor is the shape and tolerances during assembly, as even low-clearance fits can shift over time due to minor deviations.
My recommendation for rebuilding or targeted repair consists of the following steps:
1. Fully disassemble the shelf and carefully inspect all components. Damaged edges or enlarged drill holes should be identified.
2. Age-related damage can be compensated using precision drill bits and, if necessary, wood dowel repair kits.
3. After reassembly, the controlled application of glue in the dowel holes is very helpful to increase structural stability and prevent the joints from loosening in the future.
4. Optional: Use small interior brackets or so-called reinforcement brackets on the back for additional stability, without negatively affecting the visible design.
The correct sequence and precise alignment of the individual parts during assembly are also crucial. Additional tips:
- Always check with a carpenter’s square or angle gauge to ensure all connections are right-angled.
- Use wood glue that dries clear to avoid affecting the appearance.
- Do not subject the shelf to heavy loads immediately after assembly; allow it to rest for about 24 hours.
Before completely rebuilding, I recommend a thorough analysis to determine whether the cause of the problem is actually incorrect assembly or material wear. Sometimes a complete rebuild is unavoidable, but often small repairs and a bit more care during assembly are sufficient.
annagla schrieb:
My question is therefore: Do I need to completely rebuild the shelf to permanently fix this problem, or are there other tips or tricks to prevent the compartments from coming apart without having to take everything apart?
That is the key question. If the composite material is still intact and no drill holes are worn out, you can counteract the problem with targeted repairs. However, if you notice significant deformation or looseness, a rebuild would be the more durable solution.
