ᐅ KALLAX combined with IVAR – does it work?
Created on: 28 Feb 2022 08:47
elinne
elinne
28 Feb 2022 08:47
I am currently looking into how well the two popular shelving systems KALLAX and IVAR from IKEA can be combined without causing stability issues or visual inconsistencies.
Specifically, I’m interested to know if anyone has experience using KALLAX shelves as a base and expanding or connecting them with IVAR shelves or components—for example, by using shared fasteners or creative mounting methods. I find this idea useful to take advantage of both systems’ benefits (e.g., the drawers and boxes from KALLAX combined with the modularity and flexibility of IVAR).
It would also be helpful to get tips on stabilization and any notes on dimensions or weight differences that might be important when joining these two types of shelving.
So, can this really work, or is it more problematic?
I look forward to your opinions and experiences!
Laurence
28 Feb 2022 09:23
Hello elinne,
Your question about combining KALLAX and IVAR is very sensible and comes up quite often. Basically, the two systems differ in construction and material thickness. KALLAX is made of laminated MDF with a foil coating, while IVAR is crafted from untreated pine wood, which significantly affects weight and stability.
The combination is technically feasible, but some points should be considered:
1. Fastening: Since the materials differ, standard connectors are often incompatible. It is recommended to use special screws and brackets to ensure a secure connection.
2. Appearance: KALLAX has a more modern, smooth look, while IVAR appears rustic and natural. If you want a uniform look, you can paint or oil IVAR before assembly.
3. Dimensions: The measurements are not exactly the same. When aligning and adjusting height and depth, it is advisable to measure carefully in advance.
4. Stability: IVAR is very sturdy, whereas KALLAX is less load-bearing under point loads. If the combined shelving will bear heavier weight, additional reinforcements should be considered.
In summary: it works if you pay attention to fastening, dimension adjustment, and stability. This requires some DIY skills but is worth it for customized solutions.
I hope this helps!
V
Victor54
28 Feb 2022 11:38
That is already a significant difference. Without careful preparation, the joint will not remain stable over time. There is a discrepancy in material flexibility and shrinkage, especially with IVAR wood, which expands and contracts considerably depending on humidity.
Laurence schrieb:
That requires some craftsmanship skills
I agree – and would add that the weight of the IVAR components can quickly overload the KALLAX structure. KALLAX is designed for moderate loads, while IVAR is solid and can be much heavier. I do not recommend combining them without additional braces or an external frame support.
Furthermore, the different surface textures make achieving a uniform look difficult; in my view, only surface treatments or cladding solutions can avoid visible breaks.
Anyone who values stability and durability should therefore plan very carefully and consider reinforcements.
dosogau
28 Feb 2022 12:04
KALLAX and IVAR can be connected, but only on the sides using appropriate screws and brackets. Measure height and depth precisely. Plan for additional reinforcement when subject to heavy loads.
KAMERON
1 Mar 2022 07:56
The combination of KALLAX and IVAR can work but requires careful planning and professional execution.
From a technical perspective, the following aspects should be considered:
- Material differences: KALLAX, made from MDF, is barely affected by humidity, whereas IVAR, being solid wood, expands and contracts seasonally. A rigid connection between the elements can therefore cause stresses.
- Load capacity and distribution: KALLAX is designed for evenly distributed loads, while IVAR is sturdy and suitable for heavy loads. When combined, it is advisable to use IVAR as the load-bearing component and avoid placing heavy loads on KALLAX.
- Fastening and connection: Depending on the design, specialized brackets and wood connectors are recommended. Accurate measurements are necessary before assembly, as the depth dimensions differ (KALLAX typically 39 cm (15 inches), IVAR generally 30 cm (12 inches) deep).
- Surface treatment: For a consistent appearance, IVAR can be painted or oiled, while KALLAX has a foil coating.
Conclusion: The connection is technically feasible but requires craftsmanship, precise planning, and possibly additional reinforcements to ensure long-term stability. It is worth trying for custom solutions or temporary setups, but the loads should be carefully assessed for permanent furniture combinations.
