ᐅ Kallax color fades in sunlight – any experiences?
Created on: 10 Jun 2022 10:13
O
oskarkeo40
I have been using several IKEA Kallax shelves for about a year now, all in white. I have increasingly noticed that the color on the shelves and the sides facing the window is fading significantly, appearing yellowish or dull.
I am wondering if anyone else has had similar experiences with Kallax in direct sunlight? I am especially interested in whether this discoloration is a general issue with the surface coating used or if it is more related to your specific light conditions.
Are there any tips on how to prevent this fading, or is repainting or refinishing inevitable after a while?
I look forward to your feedback and, ideally, concrete solutions. Thank you in advance!
BELLA34
11 Jun 2022 10:03
I treated my Kallax with furniture care product for protection; it nourishes the surface and offers some protection. However, it does not act as a UV filter. Choosing the right location is the only effective measure.
O
oskarkeo40
11 Jun 2022 11:20
enrique7 schrieb:
Window films or relocating the shelf
Thank you for your insights! They confirm my suspicion: the material quality is acceptable, but it is not designed for intense UV light exposure.
I will now try to move the shelf away from the window and use a thin white curtain. If I decide to renovate – does anyone have experience with special coatings or spray paints that adhere to melamine-coated panels and are UV-resistant?
GU-LAU60
11 Jun 2022 13:45
Repainting melamine-coated surfaces is challenging because the surface is very smooth and non-porous. Usually, special preparations such as sanding and priming are necessary.
It is better to have a professional do the job or consider using protective film, which lasts longer and is reversible.
O
oskarkeo40
12 Jun 2022 08:50
Following your advice, I have now rearranged the shelf and added a UV-protective curtain. Let’s see how it develops.
Thank you for all the professional input! The topic is definitely not simple, especially when aiming for an affordable price and design.
