ᐅ Kallax doors close less effectively in damp weather – is this the new normal?
Created on: 7 Apr 2021 09:13
Nideo
Hello everyone, I have recently noticed that my Kallax shelving unit, especially the doors, close more tightly in humid weather and sometimes even start to wobble.
Does anyone else feel that Kallax modules close less smoothly in damp conditions than they used to? I’m wondering if this might be becoming a new normal, as some other furniture manufacturers also seem to be experiencing issues with moisture affecting their wood-based or particleboard products.
My suspicion is that the materials expand or swell due to the humidity, which alters the fit.
I also find it interesting to consider whether this could be related to current climate policies or a general increase in indoor humidity, which might be changing the properties of furniture products.
I would appreciate any experiences, tips for improvement, or insights into the material technology behind Kallax and particleboard-based furniture. Thank you!
V
vin_leo
8 Apr 2021 08:54
Hey everyone, I totally understand the frustration with sticking doors! 🙂
Who doesn’t want everything to run smoothly, especially when the unpredictable April weather is raging outside?
I rubbed wax on the doors of my Kallax, which definitely slowed down the “humidity boomerang.” You could almost say it’s a little wellness treatment for the furniture! 😉
JEREMIAH38 schrieb:
I wish there were simple household tips to help in the meantime!
My advice: a bit of regular ventilation and gently readjusting the doors. Add a little patience and good spirits — and everything stays under control.
Sometimes life is like this: we have to live with small imperfections, and that’s what gives it character.
Have you ever tried using a little lubricant on the hinges? It helps the doors move more smoothly, but it’s not a cure-all for high humidity.
Khalil
8 Apr 2021 09:22
Wow, what an exciting discussion here! 🙂 I think it’s great that we can share our experiences like this.
I’ve noticed that as soon as I stabilize the indoor humidity, for example by regular airing or using a hygrometer, the doors of my Kallax units almost close like new again!
klo40 schrieb:
If moisture is a constant issue (e.g., in basements), it’s best to use furniture made from moisture-resistant materials or to seal the furniture with water-repellent coatings.
That sounds like perfect advice to me – sometimes you just have to invest a bit more to enjoy it in the long run.
I encourage you all to keep going! Sometimes it feels like a battle against the forces of nature, but with the right tips, we’ll get through it together. Don’t get discouraged! 🙂
draleo
8 Apr 2021 10:07
To complement the previous posts, here are some facts: Kallax is made of laminated particleboard, which increases in volume when humidity rises due to water absorption. Manufacturer specifications indicate a dimensional change of about 1-2% with relative humidity between 30% and 80%.
This change is reversible, meaning that as humidity decreases, the material shrinks and returns to its original shape.
Permanent deformation or complete failure of the locking mechanism usually occurs only if excessive moisture is present over an extended period or if there is mechanical damage.
It is advisable to control the climate in the room where the furniture is placed (e.g., humidity levels between 40-60%) and to avoid direct water contact on wood surfaces.
Mechanical adjustments of the doors are standard and part of the normal usability of this type of furniture.
In the long term, particleboard is not the best choice for humid rooms or environments with very high humidity.
