A few days ago, I moved my IKEA Kallax, and I noticed that one of the corners has a broken wooden strip. It’s the outer veneer made of particleboard – the broken edge hasn’t completely come off, but a piece about 10 cm (4 inches) long has chipped away. My question is, how can I best repair this without compromising stability and making it as invisible as possible?
Maybe someone knows suitable adhesives, fillers, or has practical tips on how to repair it so the Kallax will be solid and reasonably presentable afterward?
I’ve already considered wood filler and glue but am unsure if that will hold and whether I need to sand or prime first. Also, I’m not exactly sure how to ideally paint or protect the surface afterward.
Any ideas and help are very much appreciated!
flo-Theres20 Dec 2024 07:04I would add that as preparation for painting, you should lightly sand the repaired area with fine sandpaper to create a matte surface; otherwise, the paint may not adhere well.
It is also advisable to apply a primer after filling, especially if you want to maintain the Kallax color tone as consistently as possible.
If the appearance is very important, you can try applying several thin coats with a small brush instead of one thick layer, which achieves a more even result.
At the same time, a clear furniture or protective varnish will provide a more durable finish.
notobias schrieb:
I’m not exactly sure how to ideally paint or protect the surface afterwards.That can be easily managed! I recommend using a satin acrylic paint after sanding, as it helps seal the surface while maintaining a natural appearance.
Filippo schrieb:
Do you already have a paint color match for the surface?If you don’t have the exact shade, you might consider slightly refreshing the color in that area to help conceal the repair spot.
One more tip: before painting, mask off the surrounding area with painter’s tape to avoid getting paint where you don’t want it.
Don’t worry, you can do this! 🙂 If you have any questions about the exact process, feel free to ask.
