ᐅ KALLAX Broken After Moving – Is It Better to Buy a New One?
Created on: 12 Sep 2022 18:13
Maukin
Maukin
12 Sep 2022 18:13
Hello everyone, I recently rearranged my IKEA KALLAX shelf because I wanted to change the configuration of the compartments. Unfortunately, I noticed that one of the wooden parts cracked along the edge and even partially broke.
My specific question is: In case of such damage, is it better to replace the entire KALLAX shelf, or are there effective ways to repair the damaged part without significantly compromising stability?
The shelf is about 3 years old and has been used normally, without overloading or similar issues. I heard that KALLAX is not made from solid wood but rather from pressed wood and laminate, which might make repaired areas more fragile.
I look forward to your experiences and advice, especially regarding whether a repair is economically and practically worthwhile, or if replacing the shelf is the better option. Thanks in advance!
gilen
12 Sep 2022 20:47
Maukin schrieb:
Should I just buy a new KALLAX shelf for damage like this, or are there reasonable ways to repair the damaged part?
Hello Maukin, that’s a valid question. KALLAX shelves are usually made of particleboard with a melamine coating, which is not easy to repair if the wood is cracked or broken.
Using wood glue can provide some stability, but the appearance often remains noticeably affected, and the strength under heavy load is not always guaranteed. For small cracks, you can try using suitable adhesives and possibly reinforcements, such as small brackets or wooden strips on the inside.
However, if a load-bearing side is broken, buying a new shelf is often the safer option. Especially if the shelf is subjected to weight, a repair could lead to further issues over time.
I would recommend carefully assessing the damage: How big is the break? Is only one part affected? If you’re unsure, I’m happy to offer advice on evaluating the damage.
Nathanaelk
13 Sep 2022 09:35
Regarding the topic "KALLAX broken after moving – better to buy new?" here is my detailed assessment:
A KALLAX is made from a type of coated particleboard, which is relatively thin and whose stability mainly depends on the original assembly and the cohesion of the components. When the modules are moved or repositioned, the joints can be put under stress. If one side breaks at the edge, it is important to check whether only the surface or the entire panel is affected.
- Repair:
+ Small cracks or peeling laminate edges can be fixed with wood glue (such as PV system glue).
+ For larger breaks, I recommend wood filler that can be sanded and painted over after it hardens. Nevertheless, the material will remain somewhat weakened.
+ You can reinforce the repair from the inside at weak points using metal brackets to provide stability.
- Load capacity:
+ The load-bearing capacity of a repaired section is usually lower than the original. It is often sufficient for light storage.
+ For heavy loads or frequent movement, it can become critical and may cause new breaks.
Additionally: How large is the damaged area? Does it affect an outer wall or a divider? If an outer wall is damaged, this will be visible from the outside and the aesthetic aspect might be important to you.
In conclusion, I would say: If you are handy, repairing is worthwhile, especially to save costs. However, if stability and appearance are important to you, or if the shelf will be heavily loaded, buying new is more advisable.
One more question – did you completely disassemble the shelf when moving it, or did you move it as one piece? Sometimes mechanical stresses during the move can cause such damage.
kieran
13 Sep 2022 14:22
Maukin schrieb:
Should I replace the entire KALLAX shelf due to this damage, or are there practical options to repair the damaged part...?
From a technical and factual perspective, I recommend the following approach:
1. Damage Assessment
- Check how severely the structure is affected. Is it a load-bearing component?
- Is only the surface damaged, or is the entire panel affected?
2. Repair Options
- For surface damage, repairing with wood glue and, if needed, filler material is cost-effective.
- For structural damage, repair using metal reinforcements is possible, but not advisable if the shelf will carry heavy loads.
3. Cost-Benefit Analysis
- Prices for KALLAX units are moderate. Replacement panels are not sold separately, so extensive damage often requires buying a new unit.
4. Recommendation
- For small cracks, repair is worthwhile.
- For larger breaks or if stability is compromised, replacement is recommended.
Your question is very well put, and in practice, the decision depends on the extent of the damage. The ease of replacement speaks in favor of buying new, while a repair-friendly approach is suitable for minor damage.
gilen
14 Sep 2022 10:58
Nathanaelk schrieb:
One more question – did you fully disassemble the shelf when moving it, or did you relocate it as one piece?
The answer to this question is important because moving the KALLAX unit without completely taking it apart often leads to stress and cracks at the joints.
If you fully disassembled and then reassembled the shelf, the break could also result from overtightening the screws.
Therefore, it would be helpful to know exactly how you moved and repositioned the shelf in order to better assess how the damage might have occurred and whether it is a one-time material defect or an assembly error. 🙂
