I’m currently looking into a KALLAX shelf and have a question that isn’t entirely clear to me:
The KALLAX back panel is often only installed once and is an important component for stability. However, if the back panel has to be removed and reinstalled multiple times—whether due to modifications, repairs, or other reasons—does it noticeably lose stability or hold?
From your experience, can you say after how many removals the back panel loses strength or the overall structure starts to have issues? What should be considered to ensure the shelf remains secure even after being rebuilt a few times?
I’m looking forward to your insights and practical tips!
flo-Theres20 Jul 2024 10:05Regarding the question of load-bearing capacity, I can add: The back panel primarily provides lateral and torsional rigidity and prevents sideways deformation.
If the back panel becomes loose after being repeatedly removed and reinstalled, the overall stiffness of the carcass can measurably decrease. This is not problematic under light loads but can lead to an unstable structure under heavier or dynamic loads.
Spacers are generally not an issue, provided they are quite thin and the back panel still rests fully against the frame, meaning no gaps occur that could cause wobbling. The material should also remain dimensionally stable over time to ensure that the applied rigidity does not change.
Another tip: Also check the corner joints and make sure all screws are properly tightened, as the back panel always works together with the carcass.
Narni schrieb:
I’m wondering if anyone has done something like this permanently, meaning permanently using spacers so that the back panel remains securely in place even after multiple uses.Yes, I have done this several times—mostly using tape or thin plastic strips. This is considered a reliable quick fix and does not affect stability if done properly.
flo-Theres schrieb:
The material should also remain dimensionally stable over time so that the applied stiffness does not change.Absolutely important, because if the spacer is soft or too flexible, it will tend to cause instability in the long run.
Regarding your second question: If your shelving unit is not subjected to heavy loads and is used mostly for domestic purposes, a back panel that fits slightly less tight usually suffices in practice—the unit remains stable enough.
However, if it has to bear heavy loads or is moved frequently, you should check the back panel and consider replacement parts or reinforcements if necessary.
