ᐅ KALLAX back panel warped repeatedly due to prolonged moisture exposure – possible solutions?
Created on: 13 Mar 2024 09:42
lafar34
I noticed that the back panel of my IKEA KALLAX shelf is warped in several places. After a close inspection, I suspect this was caused by mold moisture, probably from dampness that accumulated behind the shelf. What disappoints me especially is that the shelf is not even old – barely two years.
My specific question is: What options are there to permanently repair or replace the warped back panel without having to dispose of the entire shelf? Are there perhaps special back panels that offer better protection against moisture, or methods that reliably prevent dampness?
I look forward to your experiences and suggestions.
warrenka5714 Mar 2024 09:11I can fully understand how frustrating this problem is. It also took me quite a while to realize that the tilted window front and the cold wall in winter contributed to the moisture damage.
Perhaps it helps to additionally ensure sufficient ventilation and to occasionally move the piece of furniture away from the wall to allow air circulation.
Small measures helped me to avoid this—and there are certainly solutions with waterproof panels, as already mentioned here.
Josefane schrieb:
You shouldn't focus only on the repair but also on the root cause analysis – otherwise, the same problem is likely to occur again.I completely agree. The issue probably exists on several levels: on one hand, the wall absorbs quite a bit of moisture; on the other hand, there seems to be no barrier or air gap at all.
I would like to clarify further: Does anyone have experience with special waterproofing membranes or films used in construction that could be installed behind a shelf in a living space? I’m not looking for extensive drywall work but a practical solution for existing furniture and wall.
lafar34 schrieb:
Does anyone have experience with special waterproof barriers or specific membranes from the construction sector that could be installed behind a shelf in a living space?For such applications, vapor-permeable vapor retarders are often recommended, as they help direct moisture away from the wall while allowing the structure to breathe. Typical products are polyethylene (PE) membranes with a low vapor diffusion resistance factor (Sd-value).
A pure plastic sheet without vapor permeability is less suitable for interior spaces, as it can trap condensation and cause other damage.
The most effective solution is a combination of a vapor retarder plus spacers behind the shelf to allow convective air circulation.
Dopoki schrieb:
The most effective solution is a combination of a vapor barrier plus spacers to the shelf to allow convective air flow.That’s really clever! For me, such a combination made all the difference – everything stayed dry, and the shelf looks like new. 🙂
Don’t give up; this is the way to a reliable solution! 🙂
