ᐅ Kallax back panel won’t fit – any special mounting ideas?
Created on: 13 Jul 2024 09:37
Benmo
Benmo
13 Jul 2024 09:37
Some time ago, I bought a Kallax shelf unit from IKEA and I am currently assembling it with a back panel. Unfortunately, the problem is that the back panel keeps falling out of the shelf even with the slightest pressure or when in use. This is probably due to the thin MDF board and the way it is clamped to the back.
My question is: Does anyone have special or perhaps unconventional mounting ideas to fix the back panel securely and stably without having to significantly modify the shelf? I have already considered using small brackets or some kind of hook-and-loop fastener, but maybe there are other, smarter solutions.
It is important to me that the back panel lies flat as much as possible and doesn’t wobble, but I also don’t want any visible fasteners that would affect the overall appearance. I look forward to your suggestions and experiences!
benon
13 Jul 2024 11:02
Hello Benmo,
It’s great that you described your issue so precisely – that makes it easier to provide helpful advice! I’m also familiar with the problem regarding the Kallax back panel, as it is only held in place by small notches in the shelf and often doesn’t sit very securely.
A proven method is to reinforce the back panel with small, thin wooden strips. You can fix these inside the edges of the shelf using wood glue or small nails. The strips will hold the panel much more securely. Alternatively, you can use so-called panel pins or glazier’s pins, which are designed for thin panels – you press or tap these in at an angle into the frame, and they hold the back panel firmly.
If you prefer not to have visible fasteners, you can also try double-sided mounting tape. It is quite slim and presses the back panel evenly against the carcass. However, it’s important to choose a very strong, high-quality mounting tape that won’t lose adhesion over time.
If you want, I can gladly describe the exact procedure in more detail or give you some tips on the correct way to attach the strips. 🙂
Davidleo
13 Jul 2024 13:47
benon schrieb:
If you don’t want visible brackets, you can also try double-sided mounting tape.
Exactly, that’s a great idea! 🙂 I secured my Kallax with very strong mounting tape, and it’s practically “invisible” and holds really well! Especially if you don’t want to move the shelf often, this is perfect!
One more tip from me: sometimes it doesn’t stick well to MDF because of the smooth surface. In that case, just lightly roughen it with sandpaper, which significantly improves adhesion!
And if you like DIY, you can also install small magnets. That way, you can even remove the back panels if you need access behind! That’s really clever :-)
Good luck, I’m looking forward to seeing what you try!
nubar
14 Jul 2024 08:26
Benmo schrieb:
I have considered using small brackets or some kind of hook-and-loop fastener, but maybe there are other, smarter solutions.
An alternative and quite sturdy option I can recommend in such cases is installing slim metal strips or profile rails, which you screw onto the inside of the cabinet carcass. You can then essentially “slide” or secure the back panel into these rails. This provides a more stable support surface without visible screws on the front.
Another advantage is that the back panel can be easily removed when needed—such as for transport or renovation. However, it is important to install the rails precisely to avoid the back panel from warping or wobbling.
To keep the back panel firmly in place and prevent it from tilting, you can additionally attach small felt strips or silicone dampers along the top and bottom edges. These also reduce any rattling noises.
For a more permanent solution without visible fasteners, this method offers good potential for a clean and stable attachment.
