ᐅ Is it advisable to double secure the KALLAX back panel?
Created on: 15 Aug 2024 09:37
Feliciaga
Feliciaga
15 Aug 2024 09:37
Hello everyone, I am currently looking into stabilizing the IKEA KALLAX shelves and wondering if it makes sense to reinforce the back panel twice. More specifically, I am asking whether additional fixing of the back panel—such as extra screws or a second back panel—actually provides added value in terms of stability and safety, especially when using the shelving unit in homes with children or pets. Has anyone had experience with how well the original back panel holds on its own and whether doubling the reinforcement offers significant benefits? I am also interested in whether this affects the load capacity or the stress on the side panels. I look forward to informed opinions and practical advice.
gasidney
15 Aug 2024 10:45
The original back panel of KALLAX is usually sufficient to keep the shelving unit stable. If you want extra security, you can use screws or brackets. Adding a second back panel provides only a slight increase in stability. It is important that the back panel is installed correctly.
Ramon4
15 Aug 2024 11:56
Hello Feliciaga, your idea of double securing the back panel is understandable. The KALLAX back panel mainly serves to reinforce the frame and prevent twisting; however, it is relatively thin and only attached with a single layer. In households with children or pets, where the shelf is frequently moved or subjected to heavier loads, additional securing with screws or brackets on the back panel can be useful to make the shelf more stable.
However, adding a second back panel offers little extra benefit since the first panel already fulfills the purpose of stiffening. Instead, I would recommend ensuring that the back panel is properly aligned and firmly fixed. If necessary, additional fastenings could be installed on the side panels or directly into the wall to reduce the risk of tipping.
Regarding load-bearing capacity: the side panels carry the weight, while the back panel provides mainly lateral stability. Adding a second back panel does not significantly increase load capacity but rather improves durability and resistance to lateral warping. For additional safety, wall fastenings could also be advisable.
Maria35
16 Aug 2024 08:23
Ramon4 schrieb:
The KALLAX back panel mainly serves to reinforce the frame and prevent twisting, but it is relatively thin and only fastened with a single attachment.
That sums it up well. From a technical standpoint, the back panel of the KALLAX is not responsible for bearing loads. Adding a second layer or extra screws to the back panel can slightly increase torsional rigidity, but in most everyday situations this is unnecessary and more of a cosmetic adjustment.
It is important that the back panel lies flat and that all fastening points are securely fixed. For higher loads or risk of lateral tilting, attaching wall brackets or angle braces above the shelf is more effective than adding a second back panel.
An extra back panel could also make installing accessories or modifications more difficult since it reduces the interior space. Regarding the side panels, it is clear that they carry the weight, so for heavy loads attention should be paid to the quality of the assembly parts and secure connections.
Therefore, my recommendation is: install the back panel properly, use additional brackets or wall fastenings if needed, but do not add a second back panel.
