ᐅ Using Kallax for Bedding Storage – Is Dust Protection Enough?
Created on: 20 Aug 2020 13:37
korneliaHello everyone,
I am considering storing my bedding, meaning blankets and pillows, in a Kallax shelf that I already have at home. My main question is whether the Kallax shelf is really sufficient as storage furniture for bedding in terms of dust protection. I’ve read that the Kallax can be used open or with storage boxes, but how effective is the dust protection in practice?
I want to avoid the blankets and pillows getting dusty all the time, as that would mean washing them more often – which is not ideal for some materials. I might add fabric boxes, but I do not plan to use a version with lids.
Has anyone had experience with this? I am especially interested in how well open compartments in a Kallax protect against dust, whether simple fabric boxes are enough, or if I should consider another solution.
Of course, I am also open to recommendations for other ways to store bedding if a Kallax shelf is not a good option. Thanks in advance for your insights!
Hello Kornelia,
to fully answer your question "Kallax as storage for bedding – is dust protection enough?", here are a few thoughts from a technical perspective. The Kallax shelf itself is an open shelving system, which means there is air circulation in the compartments and, in theory, dust can settle inside. Of course, the dust concentration decreases depending on whether you also use storage boxes.
If you only use fabric boxes, you should know that while they do provide a barrier, the material often makes them not completely dustproof. Dust particles, especially fine household dust, can penetrate in small amounts through the weave of fabric boxes. Depending on your sensitivity – for example, if you have allergies – this could be relevant.
If you value optimal dust protection, boxes with zipper closures made of plastic or rigid plastic boxes are more advisable. They seal airtight and prevent dust from entering inside. Naturally, they are less breathable, which is usually not a problem for synthetic blankets. For down or natural fibers, you should ensure good ventilation to avoid mold.
The air circulation in the Kallax is otherwise an advantage, as moisture can escape, which is better for the bedding and indoor air quality. I would recommend changing the boxes regularly and washing the bedding depending on usage.
Finally, a question: In which environment is your Kallax located? (e.g., living room, bedroom, or basement) That also affects dust accumulation.
I hope this helps you for now!
TEBILO schrieb:
Plastic zipper boxes or rigid plastic containers are more effective at keeping out dust.That's definitely true! I use fabric boxes in my Kallax for bedding and notice that some dust can get in, but honestly, it’s not a big deal — just vacuum or air them out more often. 🙂
If you’re sensitive to dust, I would even recommend wiping the boxes with a damp cloth before filling them — that way, less dust will stick inside.
And the air circulation aspect shouldn’t be underestimated, especially with bedding. Nobody wants musty blankets in the end, right? 😉
Overall, I find the Kallax system really practical because it’s easy to access and stack neatly. But as I said: for complete dust protection, plastic boxes or even cabinets with doors are better.
sarGabriel22 Aug 2020 07:53kornelia schrieb:
whether the Kallax shelf is really sufficient as storage furniture for bedding in terms of dust protectionNo, the Kallax without enclosed boxes does not protect well against dust.
Samuel schrieb:
Just vacuum or air out more oftenExactly, regular airing and cleaning help more than relying completely on dust protection.
For better results, use fabric boxes with zippers or plastic boxes.
That’s all.
