ᐅ KALLAX as a Workbench – Preventing Screws from Stripping in Wood
Created on: 12 Jun 2024 09:17
TanelHello everyone! I have a question that has been bothering me for a while. I want to use my IKEA KALLAX shelf as a workbench to carry out small projects. The problem is that the screws I drive into the wood often crack or pull out because the wood is relatively thin and not designed to support heavy loads or be subjected to intense stress. My question is: What options are there to protect the material from screws cracking or to optimize the fastening so that screws hold securely? Are there specific types of screws or techniques to reduce the risk of screws pulling out of the KALLAX panel wood? I would appreciate your tips and suggestions, including examples of how you have solved this!
PeoDaniel12 Jun 2024 09:48Hello Tanel,
your question is very well formulated and practical, which I really appreciate! If screws are breaking or pulling out of the KALLAX wood, this is often a sign that either the screw size, the material, or the fastening technique is not ideally chosen.
First: The wood used in KALLAX is usually particleboard or MDF, both materials with limited load-bearing capacity for screws. The key is that the screw should not only grip into the wood itself but ideally into a dowel or another reinforcing layer.
Here are some tips I can recommend:
1. Use dowels: Insert plastic or wooden dowels. They distribute the load better and hold the screw more securely in the wood.
2. Screw into metal brackets: If possible, attach the workbench top to metal brackets. The brackets carry the load, and the screws only secure the brackets.
3. Pre-drill and tap threads: This prevents the wood from splitting or the screw from damaging the material when driven in.
4. Use longer wood screws with coarse threads: These hold better in wood-based materials.
5. Consider using washers: This helps distribute the force more evenly and prevents the screw from pulling out.
You might also think about alternative fasteners such as connector screws specifically designed for furniture panels.
I hope this helps you for now. If you like, I can also provide you with more precise manufacturer recommendations or sources.
PeoDaniel schrieb:
Use of wall plugsExactly, inserting wall plugs holds significantly better.
PeoDaniel schrieb:
Pre-drillingAlways pre-drill; otherwise, it will split the wood.
And it’s better not to use screws that are too thick.
Interesting discussion so far. I would like to point out that although most tips are practical, they often overlook the material limitations. KALLAX panels consist of a thin engineered wood product, which simply does not provide the same mechanical strength as solid wood or plywood panels.
Therefore, it is important not only to choose the right screws and anchors but also to consider the direction of the load: forces that apply shear stress to the screw connection are particularly critical.
Another point is the use of additional reinforcements, such as sturdy frames made of metal or wood, which stabilize the countertop and thus reduce the load on the screws. Only a mechanically better distribution of forces can protect against cracking in the long run.
This is a very good suggestion but usually fails in practice when the user continuously uses the item as a workbench. It is advisable to consider beforehand whether such a shelf is really the right material for a workbench.
Conclusion: Work in accordance with the material and with appropriate reinforcement or replace the material – otherwise, even the best screws will eventually fail.
PeoDaniel schrieb:
Screwing into metal brackets
