ᐅ KALLAX as a Toy Shelf – Too Unstable?
Created on: 25 Nov 2021 19:07
keoba
keoba
25 Nov 2021 19:07
I am currently considering whether the IKEA KALLAX shelving unit is actually a suitable solution as a toy shelf for a children's room or if it might be too unstable.
Specifically, I often read that the shelf can tip over if it is not properly secured or adequately protected against tipping. Especially with small children who might pull on it or climb, I see a potential safety risk. I have also read that the individual compartments can have varying load capacities depending on how they are weighted, which could affect stability.
Since I would like to use the shelf multifunctionally—not only for storing toys but also with larger boxes and partly as a small play area—the question arises for me: Is the KALLAX shelf truly stable enough for use in a children’s room without additional measures, or would it be necessary to install special safety features (e.g., wall anchors or fasteners)?
Does anyone here have experience using KALLAX in a children’s room with small kids and using it over the long term? How does it perform in terms of tipping resistance and durability?
Thanks in advance for your insights!
INGRID34
25 Nov 2021 20:22
keoba schrieb:
Is the KALLAX shelf stable enough to be used in a child's room without additional measures?
In my opinion, you should always secure the KALLAX shelf to the wall. Without wall mounting, there is a risk that it could tip over with small children. It’s not truly unstable, but securing it is essential.
GiRoyce
26 Nov 2021 06:14
[quote=keoba, post: h6b4r0, member: XXX]Is the KALLAX shelving unit really stable enough to be used in a child’s room without any additional measures?[quote]
I have had the KALLAX shelving unit in my twins’ bedroom for over two years. Overall, the unit is quite sturdy; the wooden panels can withstand a lot, and the craftsmanship is solid. However, children are not exactly like couch cushions—they are active and curious!
Therefore, I have always secured the unit to the wall and placed larger, heavier toy bins mostly at the bottom. This largely prevents tipping.
Since you mentioned large boxes as well: if these are not evenly distributed on the shelves, it can indeed affect stability. One tip is to weight the compartments if you use light boxes.
By the way, the 4-compartment version is more stable than the larger ones 🙂.
If you also secure the unit to the wall with anti-tip straps or brackets, in my opinion, it is completely safe for children.
I hope this helps you.
todunar
26 Nov 2021 09:33
Oh yes, the KALLAX shelf is great for toys, but definitely not a climbing support! 😄
keoba schrieb:
I see some risk that the shelf could tip over if small children pull on it or climb it.
Exactly! The shelf has been in place for a while now, and yes, securing it to the wall is essential! 😅 The kids really try everything – pulling, climbing on it, and you keep thinking, “This thing is about to fall!” 🙂
What helped us was the wall-mounting kit, which Ikea even offers as a set. Also, I fill the lower compartments with larger, heavier boxes to add extra stability. If you’re looking for something colorful and kid-friendly, there are suitable boxes that help keep it looking neat.
So, with the wall attachment, you can use the shelf safely – a great system for organizing! Good luck setting it up!
KAMERON
27 Nov 2021 13:49
keoba schrieb:
Is the KALLAX shelf stable enough for use in a child's room without additional precautions, or is it necessary to install special safety fittings?
From a technical and safety perspective, the KALLAX shelf is generally designed to be structurally sound for normal home use, but it does not come with built-in anti-tip features.
Children’s rooms present a higher risk of tipping accidents due to typical activities like climbing and pulling. Official recommendations (for example, from TÜV and consumer protection agencies) advise that furniture taller than 60 cm (24 inches) should always be secured to the wall to prevent tipping.
Depending on the model, KALLAX ranges from 42 to 147 cm (16 to 58 inches) in height, so it usually falls into the category where wall anchoring is strongly recommended.
Additionally, uneven weight distribution in the compartments—such as placing heavy items on top and light ones below—can affect stability.
My advice: always use wall fixtures, ideally the safety kit offered by IKEA or equivalent mounting hardware. Heavy items should be stored in the lower compartments to keep the center of gravity low.
These measures are necessary and comply with safety requirements for furniture used in children’s rooms.
