ᐅ KALLAX as a Toy Storage Unit Outdoors – Is It Weatherproof?
Created on: 15 Oct 2023 08:33
Dangi
Dangi
15 Oct 2023 08:33
I am considering using the well-known IKEA KALLAX shelf as an outdoor toy storage unit for the garden. The shelf would be placed in a covered area but would still be exposed to moisture and temperature fluctuations—not fully protected like it would be indoors.
My main question is: Is the KALLAX shelf weather-resistant enough to be used outdoors as toy storage without quickly swelling, warping, or damaging the surface coating? Or would it be better to choose another material that is specifically designed for outdoor use?
Additionally, I am interested in any practical tips on how to make the furniture more weatherproof (e.g., sealing, covering, placement).
I want to plan for durability, as the toys will be stored outside for several years. Looking forward to your opinions!
bapar
15 Oct 2023 09:47
Dangi schrieb:
Is the KALLAX shelf weather-resistant enough to be used outdoors as a toy storage cabinet without quickly swelling, warping, or damaging the coating?
A very good question.
The IKEA KALLAX is made from a wood-based composite, usually particleboard with a melamine coating. While this coating protects against moisture indoors, it is not designed to be weather-resistant. This means that with prolonged exposure to moisture or temperature fluctuations, the material is very likely to swell and deform.
The biggest risk is the combination of moisture AND changing temperatures, which causes the composite material to expand. The back panel of the shelf is usually thin and especially vulnerable to moisture damage.
However, there are ways to better prepare the shelf for outdoor use:
1. Location choice: A fully covered shelter with adequate air circulation and minimal direct exposure to rain.
2. Protective coating: An additional impregnation or sealing with a weather-resistant wood or varnish protection can extend durability.
3. Floor protection: The shelf should never stand directly on damp ground, but rather on wooden battens, decking boards, or a water-repellent base.
4. Replace the back panel: A thicker, waterproof back panel, for example made of plastic sheets, can prevent moisture ingress from behind.
Without these measures, I would not consider the KALLAX truly weatherproof. Occasional exposure to humidity or splashing water might still be manageable, but constant moisture or winter weather conditions should be avoided.
I’m curious about the exact nature of the placement area. Will the shelf really stand unprotected, or is there a roof or side walls?
benon
15 Oct 2023 11:03
I fully agree with the previous speaker:
The KALLAX is not designed to withstand permanent moisture outdoors. The material absorbs water, which, combined with fluctuating temperatures, quickly leads to deformation.
bapar schrieb:
The biggest risk is the combination of moisture AND changing temperatures, which causes the composite material to swell.
However, it is also worth considering that the shallow depth of the shelf makes it relatively easy to quickly bring it indoors in case of bad weather or at least cover it with a tarp. I once tried a water-repellent wood stain in a similar situation, which definitely delayed the effects. However, it will not turn the shelf into a fully weatherproof outdoor piece of furniture.
If you plan to use the shelf outside over a longer period, I would also consider the following points:
- regular visual inspections
- a slight clearance from the ground, for example, on feet or wooden slats
- as much protection as possible on the sides, especially avoiding exposure to wind or splash water
What are the climatic conditions like where you are? Does it rain frequently, or is the area only occasionally exposed to moisture?
labar43
16 Oct 2023 14:25
That’s great that you’re discussing this! 🙂
I used the KALLAX some time ago as an outdoor toy storage unit – but only in a covered garden shed where it wasn’t exposed to direct rain. For us, it lasted a few years without problems, but most of the items inside were stored in plastic boxes that provided extra protection.
benon schrieb:
a little distance from the ground, for example on feet or wooden slats
I can definitely confirm that! I placed the shelving unit on wooden blocks, which kept the bottom area dry and damage-free.
I also recommend a waterproof cover when the unit is not in use. And if it does get wet, dry it immediately. This greatly extends its lifespan.
With a bit of care, the KALLAX can certainly be used outside as a toy shelf, but I wouldn’t leave it permanently exposed to rain without protection. That said, with proper care, it works really well! 🙂
tra_nina
17 Oct 2023 07:52
To add some detail and clarify the matter precisely:
The material of the KALLAX consists of particleboard with a melamine resin coating, which generally repels moisture but is not waterproof. Prolonged exposure to moisture leads to swelling damage of the particleboard, as the core material absorbs water and expands.
According to several material tests, the melamine coating only provides surface protection and does not protect the entire furniture panel. The back side and all cut edges have a minimal protective layer, which is particularly vulnerable.
Recommended measures to extend the product’s lifespan according to various experts:
- Reinforcement of the back panel with waterproof materials (e.g., plastic sheets)
- Treatment of cut edges with wood preservative varnish
- Placement in a covered area with good air circulation
- Raising the unit off the floor
I would advise against storing the KALLAX permanently outdoors without protection, and recommend using it only in covered areas. For unprotected outdoor use, wood with durability class or plastic shelving units with UV and water resistance are more suitable.
If anyone is interested in exact sources and test procedures, I can provide more information upon request.
warrenka57
18 Oct 2023 12:08
Even though the KALLAX is not ideal for outdoor use, I understand that sometimes you want to make do with the materials you have.
labar43 schrieb:
With a bit of care, you can definitely use KALLAX outside as a toy shelf, but I wouldn’t leave it permanently exposed to rain without any protection.
That sums it up well. You should also keep in mind that as parents, it’s easy to get frustrated when nice furniture gets damaged quickly and you have to replace it sooner than expected. In my opinion, if you mostly use the cabinet during the day and bring the toys inside in the evening or when the weather is bad, you’re already doing a lot to protect it.
What helps me is establishing a clear routine, and involving the kids can even be fun.
However, I also want to emphasize: if you are uncertain about durability, it’s better to choose something specifically designed for outdoor use. That way, you’ll worry less about the kids’ toys and can be more relaxed in the long run.
Do you have a permanent roof or cover where the shelf will be placed, or will it be standing more exposed?
