ᐅ KALLAX as a Media Cabinet – How to Hide Cables Effectively?
Created on: 24 Jun 2022 08:37
Shlomo
Shlomo
24 Jun 2022 08:37
I am planning to use a KALLAX shelf unit from Ikea as a media cabinet to neatly house my AV system and various devices like a router, gaming console, and receiver. The shelf is very versatile, but routing and hiding the cables is causing me some headaches.
How do you manage cable routing with a KALLAX system to keep all cables as hidden as possible, neatly bundled, and easily accessible? I want to avoid visible or tangled cables that look messy, while still having good access to connections for swapping or checking. Do you have tips for smart cable channels, drilling holes, special clips, or DIY solutions that work especially well?
I would really appreciate suggestions or even pictures of solutions from your own setups.
Thanks in advance!
KUDAISY
24 Jun 2022 09:12
Hello Shlomo,
your question about invisible cable management in the KALLAX shelf is really important, as this system with open compartments can quickly look messy.
My advice is to first plan where each device will be placed and how power and signal cables will run. A practical sequence:
1. Back panel holes: You can drill small holes in the back panel of the KALLAX to route cables behind it and keep them out of sight. Make sure not to drill into load-bearing parts and use a thin wood drill bit.
2. Internal cable ducts: IKEA does not offer suitable channels, so I recommend flexible cable sleeves from a hardware store or special cable trays that you can attach inside or outside the shelf.
3. Cable ties & hook-and-loop straps: For bundling cables behind the shelf or inside compartments, hook-and-loop cable ties work very well. They are reusable and protect the cables.
4. Use of hooks or clips: Small self-adhesive clips can be attached inside the KALLAX compartments to guide cables along the edges.
Summary:
- Holes in the back panel
- Flexible cable sleeves or ducts
- Cable ties/hook-and-loop straps for bundling
- Clips for cable guidance
Important: Test with a provisional setup before drilling holes to ensure you have the easiest access for connections.
I hope this helps! If you want, I can also provide links to recommended products.
sarlo
24 Jun 2022 12:44
Hello Shlomo,
I would like to add some general thoughts to KUDAISY’s useful advice:
The KALLAX shelf is made of simple MDF panels, which offer great flexibility but do not have built-in cable conduits. Therefore, the key to good cable management is usually a combination of:
- Making your own holes in the back panel or through the shelves,
- Using cable channels (for example, flat ones for the back panels, or spiral wraps for secured bundling),
- And having a clear plan for device placement to avoid unnecessarily long cable runs.
One tip I often use myself: Instead of running cables just behind the shelf, you can add an attractive cover made of thin wood or plastic sheet to the back, which not only looks good but also hides the cables. The added advantage is that when you remove this cover, you can still access all the connections without unplugging or pulling on cables.
KUDAISY schrieb:
Cable channels inside: IKEA doesn’t offer suitable channels itself, so I recommend flexible cable sleeves from hardware stores or special cable trays
This is really important: Even small clips and Velcro straps can work wonders to keep cables from hanging loose.
I also think it’s important to keep power cables and signal cables separate to reduce interference. For example, if you have a router and an amplifier, this really helps.
What does your technical setup look like? Do you want to mount power strips inside the shelf? If so, planning holes near the power source is advisable.
From my experience: try a lot, avoid fixing things too early, and in the end, it’s best to integrate a power strip with surge protection directly into the shelf. This way, you have more flexibility later when setting up or rearranging.
JORDON
25 Jun 2022 07:51
Hey Shlomo 😎,
here’s the deal: KALLAX + cables = potential for cable mess, but with the right approach it’s easily solvable! I like everything to look clean while still being easily accessible.
My secret tip: fixed holes drilled into the back panels, then bundle everything in a flexible spiral cable wrap. This not only looks neat but also protects the cables and can be quickly untangled if needed 😉
KUDAISY schrieb:
Cable ties & Velcro: For bundling behind the shelf or inside the compartments, Velcro cable ties work really well.
Velcro is really great! And if you cover the back of the shelf with a thin panel extension or cardboard, you won’t see any cables at all – pure magic!
One extra tip:
Make sure to arrange devices so the shortest cables can be used. Avoid cables wrapped around the shelf multiple times, it’s annoying in everyday use.
That’s how I do it, and I have to say it’s the perfect balance of “invisible” and “upgradeable.”
kulau
25 Jun 2022 20:03
Hello Shlomo,
if you want to do it properly and professionally, it’s worth customizing the construction of the KALLAX shelf and planning the cable management systematically. Here is my detailed suggestion:
First, you should carefully measure the planned devices, including cable lengths and connector distances. This way, you can accurately position the drill holes without having to experiment too much.
1. Drill holes:
Choose holes about 30–40 mm (1.2–1.6 inches) in diameter in the back panel, preferably in the center of the compartments, so you can bundle the cables centrally. For the shelves, you can make smaller cutouts at the back edge to guide cables from one compartment to the next.
2. Cable trunking systems:
I like to install flat PVC cable ducts inside the shelves, which can be attached with screws or strong adhesive tape. This allows you to neatly separate and bundle network cables, HDMI cables, and power cords.
3. Accessibility:
Maintenance is important. I recommend flexible cable protection sleeves (such as spiral or braided sleeves) that can be easily slipped on, so individual cables can be pulled out or added without problems.
4. Power strips:
Attach these directly to the side or back of the KALLAX. Make sure the position is easily accessible, for example, using hook-and-loop tape, so the strip can be replaced if needed.
5. Back panel covering:
If the shelf is placed against a wall anyway, you can use a thin back panel with cutouts for the cables. The panel hides everything and can also hold small cable ties and clips directly:
sarlo schrieb:
Instead of just leading the cables flush behind the shelf, you can also cover the back with an attractive panel made of thin wood or plastic, which not only looks good but also conceals the cables.
One more tip: before drilling, check all connectors to ensure there is enough space behind and beside the shelf so nothing gets stuck.
If you want, I can send you a list of suitable products and tools that I use myself – that saves a lot of searching.
Which devices are you planning to install mainly, and what are the cable routes (e.g., which are longer, which are shorter)?
