ᐅ Using Kallax Shelving as Storage for Household Appliances – Is It Durable Over Time?
Created on: 20 Oct 2023 18:43
kepa63
I am considering whether the Kallax shelf unit from IKEA is really suitable as a permanent support surface for heavy household appliances. Specifically, I’m interested in whether the construction of the shelf panel and the overall load capacity of the system can withstand appliances like washing machines, dryers, or larger kitchen devices over the long term without sagging or becoming unstable.
What are your experiences with this? Have there been any durability issues when repeatedly placing heavy appliances on the Kallax over several months or years? Or are other shelving systems better suited for this purpose?
I would greatly appreciate expert opinions and experiences, including technical details about the load-bearing capacity of the Kallax shelves.
Thanks in advance!
farGlen
20 Oct 2023 22:18
Additional reinforcements often help. Metal brackets under the slab or extra supports in the middle reduce deflection. Nevertheless, the base material remains relatively thin.
U
usbla
21 Oct 2023 08:49
Regarding reinforcements: there are system solutions using standard metal profiles or even custom constructions with aluminum angles that can be mounted under the shelves. This helps distribute the weight more evenly and reduces the pressure on the particleboard.
I have also seen calculations indicating that adding support at least in the middle of the shelf compartments can increase the load capacity to about 25–30 kg (55–66 lbs).
However, caution is advised here, especially with devices that cause not only static but also dynamic loads (such as vibrations and oscillations).
For permanent loads over 20 kg (44 lbs), I recommend metal shelving or systems based on solid wood.
Paunon
21 Oct 2023 09:41
I have been using a Kallax as a small stand for my kitchen machine, which weighs about 10 kg (22 lbs). So far, no issues, but it has only been a few months.
Timmyse36
21 Oct 2023 10:12
I completely understand that safety is important to you. Especially with equipment that has weight and movement, nothing should be shaky or unstable.
Maybe it’s worth considering using the Kallax just as a visual element and placing the heavy equipment on a separate, sturdy table or surface. This way, you can have the best of both worlds. 🙂
geralu
22 Oct 2023 07:36
In my experience, Kallax shelves hold up well under regular use with moderate weight for several years. However, when the load approaches 20 kg (44 lbs), you may notice a slight sagging after about 1-2 years.
Recommendation: Do not place heavy equipment directly on the shelf. Instead, use a reinforced board as a base. Weight distribution is crucial.
