ᐅ Using Kallax as a Shoe Rack on the Terrace – How to Make It Weatherproof?
Created on: 18 Jan 2024 19:03
Takau37Hello everyone, I am considering using an Ikea Kallax shelf as a shoe rack on my terrace, since I currently have no other practical storage there. The problem is, of course, that Kallax is not designed for outdoor use and is likely sensitive to moisture and weather conditions. My question is: what measures would you recommend to make a Kallax shelf weather-resistant without completely rebuilding it? I am thinking of options like special stains, paints, or perhaps some kind of weatherproof cover or protective sheeting. Are there any experiences with how well this furniture actually holds up outside if treated? I am looking for a long-lasting solution so the storage space can be used during winter and rain without the shelf swelling or developing mold after a short time. Thanks in advance for your advice!
Takau37 schrieb:
My question is: What measures do you recommend to make a Kallax shelf weatherproof?Kallax is basically made of coated particleboard, which is not designed to withstand moisture. To make the shelf weatherproof for outdoor use on a terrace, I recommend the following steps:
1. Thoroughly sand the surface to roughen the coating.
2. Apply several coats of a high-quality, water-repellent wood varnish or clear lacquer—preferably one with UV protection.
3. Seal all edges and the back panel as well, since moisture can penetrate there.
4. Optionally, use a custom-made cover or a waterproof fabric for additional protection.
Important: Even with these measures, this remains a compromise solution. Long-term durability outdoors can only be achieved with specially designed outdoor furniture.
FAVALERIE918 Jan 2024 19:39Do not apply additional surface fillers, as the material may swell. It is better to use clear, breathable varnishes. Place the base frame on feet to prevent standing water underneath.
Hello Takau37, I completely understand your concern. Kallax is really not designed for outdoor use. If you still want to use the shelf on your terrace, I recommend protecting it from moisture by applying several coats of acrylic or polyurethane varnish. It is especially important to thoroughly seal all cut edges, as water can most easily penetrate there and cause the material to swell.
Additionally, I would place the shelf on raised supports, such as small furniture feet made of plastic or wood, to keep it off the ground and ensure proper water drainage. A roof or covering is also helpful, because even the best protection does little good if rain continuously drips onto the surface.
If you are handy with construction, you might also consider installing a water-resistant back panel made of plastic. This significantly reduces moisture exposure. A combination of coating and structural protection tends to give quite good results.
Kinbu schrieb:
A canopy is also helpfulAgreed, and here’s a fun tip from me – grab a weatherproof, transparent plastic tablecloth and drape it over the shelf when you’re not using it. They’re affordable, easy to cut to size, and actually don’t look bad at all. Add some colorful shoe inserts, and the terrace takes on a mini impressionist style 🙂
Joshbe schrieb:
Seal all edges and backs as wellExactly. That’s where the material often swells. Same tip: use furniture feet with seals to prevent splash water from rising up from below. For indoors, Kallax is great; for outdoors, just take protective measures – it’s worth the effort if done smartly.
However, I would question the basic idea: Kallax as an outdoor shoe rack? The backing board and chipboard are simply not suitable for moisture and temperature fluctuations. Even the best painting or sealing will not prevent cracks and swelling over time because the materials are not designed for this.
I completely agree. I would rather recommend investing in a genuine piece of outdoor furniture made from weather-resistant materials, which is more sustainable and more cost-effective in the long run.
If you absolutely want to use Kallax, at least the chipboard would have to be completely replaced with impregnated wood that is properly treated – which then is more like a rebuild than a conversion.
Joshbe schrieb:
Long-term durability outdoors can only be achieved with special outdoor furniture.
