ᐅ Kallax Shelving Unit Unstable as Room Divider During Draft – Has Anyone Experienced This?
Created on: 22 Oct 2020 17:23
Dusar48
Dusar48
22 Oct 2020 17:23
Hello everyone, I have a question that might also be relevant for some of you: I am using an IKEA Kallax shelving unit as a room divider in my apartment. Unfortunately, I have noticed that it tends to wobble or feel unstable when there are stronger drafts or when windows or doors are open. The Kallax unit is actually designed to be stable, especially when used as a room divider, since it is quite tall and holds a lot of weight. I’m wondering if anyone else has had similar experiences and if this is a common issue, or if it might be related to the assembly, placement, or possibly missing additional securing measures? And if so, how did you solve the problem? Looking forward to your opinions and tips!
Jatau
22 Oct 2020 17:34
I had the same issue once. Simply secure the shelf to the wall using brackets. This immediately increases stability and prevents wobbling caused by drafts.
putan
22 Oct 2020 18:06
Jatau schrieb:
Simply fix the shelf to the wall with brackets.
Exactly, that’s the number one trick – a bit of screw power, and the room divider is more stable than many a dining table at family meals 😄
If that’s not possible, you can also place heavy boxes or books at the bottom – this adds weight at the base and reduces the risk of tipping over. Good old physics, but it really works great! 🙂
tolokau
23 Oct 2020 10:15
To examine the topic in more detail: The Kallax shelving unit is modular and made with thinner particleboard panels. When used as a freestanding room divider and it wobbles due to drafts, this is often caused by the following factors:
1. Missing attachment: Kallax is not designed to stand securely without being fixed to a wall.
2. Uneven floor: Even small floor irregularities can lead to instability.
3. Missing or improperly installed back panel: The back panel reinforces the stability of all compartments.
4. Uneven load distribution: If the shelf is loaded more heavily at the top or on one side, the risk of tipping increases.
My advice: First check that the back panel is properly fitted and that the shelf stands flat on the floor. Then take measurements with a spirit level and, if needed, use small felt or plastic pads to level it. If you regularly open doors or windows for ventilation, I strongly recommend securing the unit to the wall or adding extra bracing. This will significantly improve stability.
In conclusion: There is also special Kallax hardware available for attachment that you should consider. It is important to limit the forces on the unsecured furniture caused by drafts.
kogudra
23 Oct 2020 11:48
Dusar48 schrieb:
The Kallax shelf is actually designed to stand firmly, especially when used as a room divider, because it is quite tall and supports a lot of weight.
This is a common misunderstanding. Kallax shelves are primarily intended as surface units, not as freestanding room dividers without additional stabilization. The design is not made to withstand significant lateral forces or sudden movements caused by drafts.
I recommend adding extra weighting at the base of the shelf, as putan mentioned, or reinforcing the back panel. Alternatively, you can install support strips along the vertical sides – this reduces rattling and significantly increases stability. Also, when used as a room divider, the shelf often experiences loads that Kallax is not specifically designed to handle on its own.
Surela
24 Oct 2020 08:09
I would like to go into a more technical discussion, as the issue with freestanding shelving units is sometimes underestimated.
The IKEA Kallax is a relatively lightweight shelf with a thin back panel made of plywood, primarily designed to provide stability in the plane (i.e., to prevent lateral twisting). However, this component will not be able to absorb strong leverage forces or fluctuations caused by air pressure gusts.
When there is a draft, a dynamic pressure difference occurs between the two sides of the shelf. This causes vertical airflows that can push down the shelf on the lighter side and lift it on the opposite side, resulting in wobbling due to the lack of anchoring.
The following measures are possible:
- Wall mounting using metal brackets to transfer lateral forces into a rigid structure (wall).
- Increasing the shelf's own weight, for example by adding boxes, books, or additional weights at the lower part.
- Adding cross braces or diagonal reinforcements in the back panel area.
- Alternatively, using a combination of two shelves that stabilize each other.
If possible, it would be helpful to know in which room the shelf is located (hallway, living room?), the size of the air passage through windows or doors, and whether there are other sources of drafts. Sometimes simply narrowing the air passage with heavy curtains can help.
