cassandrav15 Sep 2020 14:22I am planning to use an Ikea KALLAX shelf unit as a base cabinet for my printer and wonder if the furniture can support the weight of a typical printer over time. Specifically, I am concerned about the stability and load-bearing capacity of the shelf when a medium to large inkjet or laser printer is placed on top—including possible vibrations during printing. I am also interested in whether the KALLAX construction, especially the glass shelves (if used), is designed to handle this kind of load or if additional reinforcement would be advisable. Does anyone have experience with this or can provide technical insights?
The KALLAX shelf unit is generally designed for evenly distributed loads, not for point loads like a heavy printer that also vibrates during operation. Depending on the model, the wood-based panels have a maximum load capacity of about 13–15 kg per shelf (29–33 lbs). If the printer also produces vibrations, the wood may fatigue over time. My advice: If you want to use the KALLAX as a printer stand, place it on the lower shelves or add extra reinforcement (for example, metal brackets or a sturdy wooden board as a base). I would not recommend a glass shelf, as glass does not withstand dynamic loads well over time.
In addition to the technical explanation, here are a few practical tips: Many users actually place small to medium-sized printers on KALLAX shelves, but without glass shelves. As Giagau already mentioned, the standard wooden shelves are designed for a maximum load of about 13 kg (29 lbs). A medium-sized inkjet printer typically weighs around 7–9 kg (15–20 lbs), but a larger laser printer can easily reach 15 to 20 kg (33–44 lbs) – which may no longer be suitable. Therefore, you should also consider that the weight does not have to be evenly distributed and that vibrations, especially from laser printers, can be more intense. I recommend staying well below the maximum load and rather using additional supports. Alternatively, you can place the printer directly on top of the KALLAX unit, as the overall platform is often more load-bearing.
laume schrieb:
The standard wooden floors are designed for a maximum load of about 13 kg (29 lbs). This is important. It’s better to stay below or on top of this limit; do not use it as a shelf board.
Hey, great topic! 🙂 I’m using my KALLAX as a printer stand myself and can say that it works really well! I placed my printer directly on the top shelf and haven’t had any issues with sagging or instability so far. Of course, my printer only weighs about 8 kilograms (18 pounds), but I can tell the construction is very sturdy. If you’re planning to put heavier equipment on it, you can also add an extra solid wood board on top to distribute the weight more evenly. Good luck with your project – I always enjoy seeing furniture used in clever ways! 🙂
