ᐅ KALLAX used as a plant shelf is damp – are there alternatives?
Created on: 21 Jan 2022 09:13
O
okyanusnar
I repurposed my KALLAX shelf from IKEA as a plant shelf because I found the modular design ideal. Unfortunately, I now have the problem that the shelf becomes quite damp, especially in the lower compartments, probably due to watering and evaporation. Some of the panels seem to be swelling, which I attribute to the moisture.
My question to you: Are there any good moisture-resistant or better-suited alternatives to KALLAX that are specifically suitable for use as a plant shelf? It is important that the material is less prone to water damage while still offering a similar size and structure.
I look forward to your experiences and suggestions!
rebufar
22 Jan 2022 08:42
Henry schrieb:
I have bamboo shelves, they are surprisingly lightweight and very flexible thanks to the slot-in system.
That sounds interesting, but this type of construction can also become unstable. I still believe that cheap slot-in systems are not suitable in the long run for plant shelves carrying heavy weight and exposed to moisture.
Maybe it’s better to choose traditional solid wood shelves that can be treated afterward for protection.
JONKO
22 Jan 2022 09:12
What also helps me with plant shelves is a waterproof covering for the shelves, so the rack stays dry while still allowing the plants to be positioned well.
Often, it’s less about the shelf material itself and more about water sitting for too long. Otherwise, bamboo is actually similar to wood in handling but has a natural resistance.
praWarre69
22 Jan 2022 10:03
I also think it’s best not to make things too complicated. A bit of water-repellent spray lacquer, good coasters or trays, and a little skill when watering is usually enough.
And hey, plant shelves are a bit of an adventure too – you just have to accept the occasional small mistake 😉
O
okyanusnar
22 Jan 2022 10:52
Thank you all for your helpful answers and suggestions!
Summary for me: Unfortunately, KALLAX is not ideal due to moisture; bamboo and teak wood with proper treatment seem to be good alternatives; metal is an option but doesn’t always fit aesthetically; coatings can help but need to be chosen carefully; and very important: use plant saucers and ventilate!
I will now specifically look for bamboo shelves with good sealing as my next project.
It’s great to see so many perspectives gathered here—thanks again to everyone!
kogudra
22 Jan 2022 11:25
okyanusnar schrieb:
I will specifically look for bamboo shelves with good sealing as my next project.
If you want, I can gladly send you a list of manufacturers or suppliers for durable bamboo furniture.
Good sealing products for wood and bamboo are usually available at specialist woodworking stores. They often have better access to sustainable solutions than general hardware stores.
Henry
22 Jan 2022 11:38
Great that you now have a plan. I’m keeping my fingers crossed that the bamboo option works out well.
Sometimes it takes a few attempts, but that’s part of the appeal. 🙂
