ᐅ KALLAX used as a plant shelf is damp – are there alternatives?
Created on: 21 Jan 2022 09:13
O
okyanusnar
O
okyanusnar
21 Jan 2022 09:13
I repurposed my KALLAX shelf from IKEA as a plant shelf because I found the modular design ideal. Unfortunately, I now have the problem that the shelf becomes quite damp, especially in the lower compartments, probably due to watering and evaporation. Some of the panels seem to be swelling, which I attribute to the moisture.
My question to you: Are there any good moisture-resistant or better-suited alternatives to KALLAX that are specifically suitable for use as a plant shelf? It is important that the material is less prone to water damage while still offering a similar size and structure.
I look forward to your experiences and suggestions!
chenValeri
21 Jan 2022 09:47
I would rather recommend metal shelves, as they are water-resistant and sturdy. Alternatively, shelves made of plastic, which resist moisture.
Henry
21 Jan 2022 10:01
That sounds quite frustrating with the moisture in the KALLAX. I also have some plants on a wooden cube, and a waterproof coating helps me. Maybe that could be a temporary solution for you before you make a change.
Linavin
21 Jan 2022 10:35
Henry schrieb:
I also have some plants on a wooden cube, and a waterproof coating helps me with that.
Is this really effective in the long term? Especially with heavy evaporation and water splashes, moisture can still penetrate, particularly at the edges. Additionally, there are health concerns related to coatings used indoors and around plants.
Also, regarding the original question:
Which alternatives actually offer better moisture resistance without such implications? Could a metal shelf, as @chenValeri suggested, be suitable here? But how do temperature fluctuations affect it? Is it practical to place something like that in living spaces?
O
okyanusnar
21 Jan 2022 11:13
Henry schrieb:
Maybe this could be a temporary solution for you before you switch.
Thanks, the idea of painting is interesting. Have you been recommended a specific paint or tested one yourself that won’t harm plant health? I’d prefer not to introduce too many chemicals into the room.
Also, I like the suggestion about the metal shelf, but the look should still feel reasonably homey – do you have any specific recommendations? I’m aware that in damp conditions I need to use materials other than wood panels, but I really like the KALLAX because of its layout and easy combinability. Maybe there are wood shelves with coatings or alternatives made of bamboo or something similar?
JONKO
21 Jan 2022 12:04
Don’t worry about the moisture! I once had a wooden shelf where water would always run down after watering. I simply placed a large mat under each pot so the water wouldn’t drip onto the shelf.
Regular ventilation also helps to prevent moisture from just staying in the room or on the shelf.
But if you want to try something completely different, bamboo shelves are resistant to moisture – a natural protection. They also look nice.
