I am considering using an IKEA Kallax shelving unit as a kitchen cabinet to create additional storage space. I am aware that Kallax is originally designed for living rooms and offices, but since the dimensions are quite practical, I would like to use it in my kitchen. My question is: What potential issues might arise when using a Kallax unit as a kitchen cabinet? I am especially concerned about moisture, stability, cleaning options, and of course the load capacity when storing pots, pans, or dishes. I would appreciate any experiences or tips, particularly regarding durability and maintenance.
Best regards!
Best regards!
MANLEN schrieb:
The flexibility and affordable priceI can definitely understand that. This is a big advantage, especially in smaller kitchens. I would like to add that the material of the melamine-coated particleboard should perform well regarding cleaning agents and heat-sensitive contact, as long as you avoid placing it directly next to the cooking surface or hot pots.
If you plan to make the surface more durable, a thin glass sheet or another heat-resistant cover could be considered. This protects against scratches and heat but is, of course, not really a DIY project.
I also recommend not placing the shelf behind doors exposed to high humidity, such as near the dishwasher or sink.
Have you considered installing a small ventilation system in the kitchen area?
FAZAR schrieb:
I also recommend not placing the shelving unit behind doors in high-humidity areas like dishwashers or sinks.Thanks, that’s a helpful tip. As mentioned, the location is more of a dry niche. We regularly ventilate, but I might consider adding a small extractor fan in the kitchen area.
So: load capacity and moisture protection should be carefully considered, especially for long-term use.
Are there any experiences regarding how long a Kallax-type shelving unit can withstand everyday kitchen conditions without deteriorating noticeably in appearance or function? Do you have any insights?
LAYNE schrieb:
Maybe also consider adding doors to the Kallax.Exactly, doors provide great protection! Plus, there are even cool colors and designs that can give the kitchen a fresh look.
Who would have thought that the Kallax could become a kitchen star? 😄
Here is a summary: Kallax can be an affordable, flexible solution as long as moisture is managed and load limits are respected. For added safety, consider protective measures such as wall mounting, rubber feet, doors, and moisture protection.
Personally, in a kitchen with high usage and moisture, I would prefer furniture that has been specially tested. However, this is always a balance between price, space, and purpose.
Thanks for the discussion, very insightful!
