ᐅ Kallax as a dust collector – has anyone tried using a filter?
Created on: 26 Feb 2022 18:23
pibego
pibego
26 Feb 2022 18:23
I have a Kallax shelf unit from Ikea in my living room, which was originally intended for storage but has now become more of a dust collector. It seems that dust quickly settles in the open compartments, and despite frequent cleaning, it remains a bothersome issue.
Therefore, my question to the community: Has anyone ever tried filters or special covers to reduce dust buildup in the Kallax? I can imagine there might be practical solutions that can be integrated almost "invisibly," without significantly limiting storage space or aesthetics.
What are your experiences with such filters or other methods that effectively prevent dust accumulation in the Kallax shelf? Thanks in advance for your advice, tips, or product recommendations!
Gino38
26 Feb 2022 19:04
I don’t have any filters made specifically for the Kallax, but generally, fabric covers placed inside the compartments can help, such as cut-to-size felt panels or thin fabrics attached with Velcro.
pibego schrieb:
Has anyone tried filters or special covers before... without significantly reducing storage space or affecting the appearance?
The appearance is, of course, subjective; I recommend using neutral colors or transparent materials when it comes to dust protection.
Additionally, activated carbon filters inside the compartments can improve air quality, but this is more of a supplement than a dust barrier.
Elodie
26 Feb 2022 20:17
I once tried using those "invisible" dust protection nets commonly used for aquariums – they can be easily cut to size and placed over the compartments. They take up hardly any space and barely affect the appearance of the Kallax. 🙂
Gino38 schrieb:
I recommend using rather neutral colors or transparent materials when it comes to dust protection.
That's true; you can get creative with it. Sometimes lightweight fabric options are much more pleasant than rigid filter panels.
CARLA
27 Feb 2022 08:46
From a professional perspective, the most effective dust protection for shelving units like the Kallax is a combination of physical barriers (covers or fronts) and regular cleaning.
Custom filter solutions are rarely available as standard, since the Kallax compartments have rectangular and open openings. For a simple implementation, I recommend using plexiglass or acrylic panels, which can be attached with suitable brackets.
These prevent direct dust infiltration while keeping the storage space accessible. Of course, this depends on how often you need to access the contents.
pibego schrieb:
Are there practical solutions that can be integrated "invisibly" without restricting the storage space too much?
Transparent panels are a good answer here.
TARAON
27 Feb 2022 10:12
I came up with my own solution for my Kallax: I attached magnetic strips to the inside and used thin sheets with magnetic strips. This way, you can close the compartments with the sheets and easily remove them when needed.
CARLA schrieb:
I recommend plexiglass or acrylic panels... They prevent dust from getting in directly.
I had considered that too, but the magnetic sheets are more flexible and make it easier to access the contents. It works great and looks neat!
A small downside: you need to clean the sheets from time to time – but the dust stays outside.
KAMERON
27 Feb 2022 14:29
Another option is to retrofit the compartments with sliding doors. There are suppliers online offering custom-fit doors for Kallax units, often made of wood or plastic.
TARAON schrieb:
Magnetic strips and films to close the compartments... work really well.
These doors are much more durable than films and also protect against moisture and more significant dirt. The downside is the cost and, of course, that they change the open shelving concept.
