ᐅ Kallax as a Cover for Radiators – How Do Temperature Fluctuations Affect It?
Created on: 24 Jun 2020 18:37
Lolebe
Lolebe
24 Jun 2020 18:37
I am currently considering whether I can install my Kallax shelves as covers above my radiators. I am mainly wondering how the temperature fluctuations might affect the material and stability of the Kallax units. The radiators get quite warm during the day, and cool down again at night—so there are constantly changing temperatures.
My specific questions are:
1. Can the heated air currents from the radiators warp or even damage the Kallax material?
2. How does the long-term durability hold up if the shelf stands over such a heat source?
3. Are there any special precautions or installation tips to avoid problems?
I do not intend to connect the shelf directly to the radiator, but rather to use it as a cover "above" the radiator so that air circulation can still be maintained.
Thank you very much for your assessments and experiences!
Liduta
24 Jun 2020 19:46
Hello Lolebe,
First of all, an important point: Kallax is made of medium-density fiberboard (MDF) with a melamine resin coating. These materials are sensitive to moisture and strong temperature fluctuations, which usually cause slight warping or expansion.
1. Distortion due to temperature: In general, heat can cause minimal deformation of MDF, especially if the heat is direct and prolonged. Since a radiator emits warmth and is not an extreme heat source (such as a stove), you should expect small expansions in the millimeter range, which typically do not cause significant damage.
2. Load capacity and stability: The load capacity of Kallax shelves generally remains intact as long as excessive heat is avoided. However, you should ensure that the shelf is not placed directly on a very hot radiator—the effect of heat depends on air circulation and distance.
3. Installation recommendations:
- Maintain a distance of at least 5–10 cm (2–4 inches) from the radiator to allow air circulation and heat dissipation.
- Do not attach the shelf directly to the radiator, as it expands and could damage the shelf.
- Provide ventilation openings or leave existing shelf compartments open for optimal airflow.
Summary: You can place Kallax above radiators, but make sure there is sufficient distance and air circulation to minimize heat-related damage. Good luck with your project!
Jeanbar
24 Jun 2020 20:59
Hello Lolebe,
I’d like to add some basic information about heat and materials to help clarify the understanding:
Temperature fluctuations mainly cause wood-based materials like MDF to expand or contract. This is purely a physical effect and usually reversible—provided no extreme conditions occur.
Liduta schrieb:
Since the heater emits warmth and is not an extreme heat source (such as a stove), you can expect small expansions in the millimeter range
That sums it up well. The top surfaces of a Kallax shelf can slightly warp if they are directly exposed to warm airflow. Therefore, it is advisable not to completely cover the heat source and to ensure the material has enough time to expand and contract accordingly.
Liduta schrieb:
Distance to the radiator: Leave at least 5–10 cm (2–4 inches) clearance so air can circulate and heat can dissipate
Distance is really key. Installing without air circulation can cause the heater to operate less efficiently and increases the risk of moisture buildup or damage to the wood.
A specific recommendation: If possible, place a thin layer of heat-resistant material between the radiator and the shelf to prevent indirect heat transfer.
If you have more detailed questions, I’m happy to explain technical details regarding wood-based materials and thermal effects.
bupar
25 Jun 2020 07:22
From a technical perspective, the following points should be considered:
- MDF (the material used for the Kallax elements) has a typical coefficient of thermal expansion of about 3–5 × 10⁻⁶ K⁻¹. This means that with a temperature difference of approximately 30 degrees Celsius (e.g., room temperature versus radiator heat), an expansion of a few millimeters over a length of one meter could occur.
- However, moisture absorption is also important for MDF: warmer air can be drier, while cooling may cause condensation. This is the main reason for swelling or warping in wood-based materials.
- Prolonged high temperatures directly on the surface can also damage the coating, leading to discoloration or loss of surface texture.
Conclusion: The construction should be designed so that no permanent heat or moisture stress directly affects the Kallax shelving unit. Air circulation and spacing are crucial. I would also recommend reinforcing compartments exposed to direct heat with durable inserts.
Under no circumstances should the shelving touch the radiator surface, as this would restrict the expansion possibilities of the heating element.
glamo8
25 Jun 2020 08:11
Short and precise:
You should keep Kallax at least 5cm (2 inches) away from the radiator. Avoid placing any direct heat source under the furniture. Ensure proper air circulation. Otherwise, it may warp or get damaged.
This is the best protection.
floga
25 Jun 2020 09:53
I find this topic very interesting because I once tried placing furniture directly over radiators myself. My advice: proceed carefully and observe how the piece of furniture behaves. Sometimes there are small changes that you don’t immediately notice in everyday life until suddenly corners or edges start to warp.
Lolebe schrieb:
Can the warm surfaces of the radiators warp or even damage the Kallax material?
Yes, that can happen if the temperature fluctuations are too intense and especially if they affect the material directly. However, this usually occurs over a longer period of time.
If I were you, I would consider installing narrow metal or wood strips as spacers – this way you ensure safety and air circulation, and the risk of damage is significantly reduced.
Sometimes it also helps not to pack the shelves completely so that air can circulate better. Good luck! 🙂
