ᐅ KALLAX and loose back panel – what is the most secure way to fix it?
Created on: 17 Jun 2022 09:12
keo_ken
I’m facing the issue of how to securely and permanently fix the loose back panel of my IKEA KALLAX shelf unit. On my KALLAX (the 4x4 model), the back panel is coming loose in several places, especially on the lower compartments, which causes the whole unit to lose stability. The original thin nails simply don’t seem sufficient anymore—mainly because the back panel is made of thin MDF and the stability of the entire unit depends on it.
My question to the community: What methods do you recommend for additionally securing the back panel to improve stability? Has anyone had experience with screws and brackets, glue, double-sided tape, or maybe even adding an extra wood panel for reinforcement? Are there any specific tricks that make the installation easier without damaging the material?
Background: I don’t want a complicated or irreversible modification because I might want to repurpose the shelf in the future. But it should be properly secure and load-bearing, especially since I store books in it.
Thanks for your advice!
sifope
18 Jun 2022 12:47
Just a small addition: If you use brackets, be sure to check the distance to the back panel edge. Screws placed too close to the edge can pull out. With a thin back panel, it is also advisable to use a washer with the screws to distribute the force.
Additionally, I consider bonding with mounting tape to be insufficient, especially for vertical loads such as from books.
One advantage of combining both is that the adhesive provides surface-wide support, while the brackets absorb localized tensile forces. However, it is important to install both correctly.
Roberta
18 Jun 2022 13:33
sifope schrieb:
Installation strap is undersized for vertical load.
I agree, especially when fully loaded with books. Installation straps might be suitable as a supplement, but not as the sole means of fastening.
keo_ken
19 Jun 2022 08:20
Thank you all for the many helpful tips!
I think I will start by working with brackets and careful gluing at the edges. I’m still considering the idea of a thin plywood sheet, but I want to avoid the risk of warping.
Pre-drilling and screwing is also important to me, as I don’t want to damage anything.
I’ll provide feedback later on how it turned out!
One last question: Does anyone have tips for covering or visually blending the brackets? I’d like to make them as discreet as possible on the inside where they are visible.
Alberto51
19 Jun 2022 09:45
To cover the brackets, you can use color-matched plastic caps from the hardware store. Alternatively, you can stick small self-adhesive furniture films over the brackets. Sometimes, I have also used dark paint leftovers to make metal brackets less noticeable.
These are simple tricks that can also be removed without leaving any residue.
