I am currently planning to set up a Kallax shelf from IKEA in my living room, which has a laminate floor that is quite sensitive. My main question is: Can placing or using a KALLAX shelf on laminate flooring cause long-term damage? Specifically, I am concerned whether the weight or the point load from the contact areas could cause scratches, dents, or other damage that wouldn’t be easy to remove.
Has anyone had experience with this or can offer tips on how to protect laminate flooring? Perhaps there are special pads or methods you would recommend.
I look forward to your opinions and feedback, thank you in advance!
V
vincent4614 Apr 2022 11:23Sinron schrieb:
Can placing or using a KALLAX shelf on laminate flooring cause long-term damage to the floor?That’s a great question, one I wondered about myself for a long time. I have a KALLAX shelf on laminate flooring at home and can say it really depends on how sturdy the laminate is and, especially, what type of feet the shelf has. The feet on my shelf are quite narrow, so they put a lot of pressure on the floor in small areas. That’s why I put felt pads under them from the start. Since then, no scratches or dents.
Sinron schrieb:
Maybe there are special pads or techniques you would recommend.I can definitely recommend felt pads or special plastic gliders that are thick enough to better distribute the weight. Also, regularly checking and replacing them when needed helps protect the floor over time.
I know such small steps can be a bit of work, but it’s definitely worth it to preserve the laminate flooring. Hope this helps! 🙂
vincent46 schrieb:
With my shelf, the feet are so narrow that they really concentrate a lot of pressure on the floor in small spots.Honestly, if you place a KALLAX shelf directly on laminate flooring, you are probably underestimating the impact of those solid wood feet points. Laminate is not hardwood and tends to dent under pressure. Just felt pads? I think that’s quite naive.
You have to consider: A KALLAX shelf can easily hold 50 kilograms (110 pounds) or more. If the pressure is focused on the groove in the laminate by just a few centimeters (inches) of narrow feet, damage is almost guaranteed.
That’s why I think it’s better to put a sturdy board under the shelf to distribute the load evenly. But if someone says, "That’s unnecessary, felt pads are enough," then you’re just relying blindly on half-measures. Laminate is basically a soft material.
Anyone wanting to be safe should consider carefully whether such a shelf should be placed directly on laminate at all.
baAlejandr15 Apr 2022 09:54jotisi schrieb:
It should ideally be a sturdy base under the shelf, something that distributes the load evenly.I agree, but it doesn’t necessarily have to be a full concrete slab. A stable base like a thin plywood board or a plastic sheet that spreads the weight well is a practical investment to prevent pressure marks and dents on the laminate flooring.
Additionally, slip-resistant felt or rubber pads are useful to keep the shelf from sliding and avoid scratches caused by movement. It’s also important to regularly check whether the pads are still intact and free of trapped dirt particles that could damage the laminate.
Furthermore, the shelf height and overall weight are crucial factors. If the KALLAX is placed against a wall and not moved often, the risk of significant damage to the laminate floor is lower, provided an appropriate base is used.
Hey everyone!
I think this topic is not as dry as it sounds 😉 Laminate flooring can be quite tricky, but with a few tips, the KALLAX shelf can become your floor’s best friend. My advice: every now and then, take a little “floor care break” – that means briefly checking if the felt pads are still in good shape, sanding them down, or putting on new ones.
I completely agree; when you use something underneath, it almost feels like the floor is getting a little spa treatment ;-)
I also really like the idea of protecting the floor additionally with a rug or a sturdier mat at that spot. The laminate floor will appreciate it, and the KALLAX will stand super firmly. And if you add some greenery or cool decor around it, the whole corner won’t just look tidy but will feel really cozy too 🙂
So: laminate isn’t just protected – it gets a little love back.
baAlejandr schrieb:
a thin plywood sheet or a plastic panel that distributes the weight well
