ᐅ Kallax and Ceiling Height – How to Integrate It Optimally?
Created on: 17 Apr 2024 19:23
pita6
pita6
17 Apr 2024 19:23
I am currently facing the challenge of how to best integrate my IKEA Kallax shelving unit into my room without it looking awkward in relation to the ceiling height or appearing too bulky. Specifically, my apartment has a ceiling height of just under 2.40 meters (7 ft 10 in). The standard Kallax unit is about 1.77 meters (5 ft 10 in) tall, with a 4x4 grid. I am wondering if it even makes sense to use Kallax units in rooms with this ceiling height, since the furniture piece already feels quite bulky.
I’m particularly interested in tips on how to position and arrange the shelving—whether it works better lying down, standing upright, or mixed—and whether it’s worthwhile to use several smaller Kallax elements to reduce the bulky effect.
Does anyone have experience or recommendations on adapting Kallax units to ceilings just over 2.30 meters (7 ft 7 in) so that they look good visually and are still practical? Any advice on whether other IKEA systems might be more suitable would also be appreciated. Thanks in advance!
Jukin
17 Apr 2024 20:44
Hello pita6,
Your question is very well thought out, and I can easily understand your concerns about how the Kallax shelf will look in the room, especially with a ceiling height of 2.40 m (7 ft 10 in).
From my experience, the Kallax appears quite bulky when standing and fully assembled, particularly in rooms that feel low. The height of 1.77 meters (5 ft 10 in) takes up a significant amount of visual space.
One tip is to avoid placing the Kallax all the way up to the ceiling. Instead, you can use the back panel or add decorative elements on top to create a finishing height. Alternatively, stacking two 2x2 Kallax units gives you more height options (about 1.54 m + 1.54 m = 3.08 m (5 ft 1 in + 5 ft 1 in = 10 ft 1 in)), but that would be too tall for a 2.40 m (7 ft 10 in) ceiling. So it’s better to use just one 2x2 or a 4x1 unit standing upright.
If you want to experiment with the look, you can also lay the shelf horizontally—it will appear less dominant. However, keep in mind the load capacity of each compartment and the overall stability. Longer units without extra support risk sagging.
The Kallax is very versatile and affordable, so you can try combining several smaller modules to spread out the visual impact. Some people also use matching baskets or boxes to make the shelf appear "lighter."
In short: standing, it looks somewhat heavy, but using a compact arrangement (e.g., 2x2 or 4x1) along with an open room concept is usually the best solution for your ceiling height.
If you like, I can also share some photos and examples from my own home that I have posted before.
Wesley
17 Apr 2024 21:30
Jukin schrieb:
Standing, it can look a bit heavy, but the compact use (e.g., 2x2 or 4x1) combined with an open spatial effect is usually the best solution for your ceiling height.
I can only agree with that. In my apartment, the ceiling height is about 2.50 m (8 ft 2 in), and I still only have a 2x2 Kallax – it fits perfectly and doesn’t feel overwhelming at all.
My tip for you: Have some fun decorating the shelf, for example with plants or lightweight baskets. That softens the look and gives your room more personality. 😉
If you use the shelf fully at standing height, make sure to secure it to the wall. Safety first, especially if you have small children or pets in the household.
Sometimes less is more – a small Kallax placed next to it or in a niche can balance the room proportions much better. So don’t add too many pieces, or it quickly looks cluttered or tacky.
Finally, Kallax works great with creative configurations. For example, I screwed two 1x4 units on the wall, stacked one over the other, so it looks more like a purposeful, custom shelving combination rather than a typical IKEA shelf. Maybe an idea for you?
GALEO4
18 Apr 2024 07:16
pita6 schrieb:
I have a ceiling height of just under 2.40 meters (7 ft 10 in) in my apartment. The standard Kallax shelf is about 1.77 meters (5 ft 10 in) tall (4x4 grid). I'm wondering whether it even makes sense to use Kallax shelves in such ceiling heights, as the furniture piece already looks quite bulky.
I think this whole discussion is a bit overrated. In the end, it doesn’t really matter exactly how high the ceiling is, as long as the shelf is functional and works for you.
Kallax doesn’t have to “fit perfectly” visually in every room. Sometimes the goal is precisely to make a statement and show clean lines. If you always focus only on appearance, you often miss out on practical benefits.
If you’re truly concerned about how the ceiling height affects the look, just lay the Kallax flat and use it as a sideboard or room divider. Clean lines, done. But it’s still Kallax, and if you manage to integrate it usefully, it doesn’t matter if it looks “too big” visually.
I’d even argue that worries about “airiness” are exaggerated. The eye adjusts quickly, and often the feeling of space depends more on the rest of the furnishing than on a meter more or less of shelf height.
In short: Don’t overthink the appearance. If you need the Kallax, put it where it suits you best, and the sense of space will live with you.
LOGEMIN
18 Apr 2024 09:05
Here are some collected thoughts from a structural perspective:
1. Take exact measurements: Before deciding on a configuration, be sure to measure the wall height, width, and room depth accurately. A common mistake is underestimating the ceiling height. 2.40 m (7 ft 10 in) is a good reference, but especially in older apartments, there can be slight variations.
2. Choosing the Kallax size: Kallax units are not only available as 4x4. For lower ceiling heights, 2x2 (77 x 77 cm (30 x 30 inches)) or even 1x4 (147 x 39 cm (58 x 15 inches)) modules are more suitable. The 1x4 modules can be placed horizontally, which looks more delicate and makes better use of the space.
3. Combining modules: Often, using several smaller shelves instead of one large one helps. It can soften the spatial effect and also allows you to define different zones within the room.
4. Load and stability: Horizontally placed modules have a higher risk of sagging if the load is unevenly distributed. In this case, I recommend using wall fasteners or additional supports.
5. Color design: Light colors or white back panels in the modules can create a visually lighter effect. You can also consider leaving some compartments open while filling others with baskets or boxes to increase contrast.
Summary: For a ceiling height of 2.40 m (7 ft 10 in), using smaller Kallax modules in combination is usually the best choice. This avoids the overwhelming effect of a single large shelf, offers more visual flexibility, and increases design options.
If you like, I can also provide a simple sketch showing the best arrangement of the modules.
