ᐅ KALLAX and Cat Hair – Cleaning the Corners?
Created on: 5 Dec 2022 09:13
jatige
Hello everyone, I have a specific question regarding KALLAX shelves and the removal of cat hair, especially in the corners. My cat is currently shedding a lot, and the hair sticks very well in the corners and edges of the KALLAX shelf. I find it quite difficult to clean thoroughly and permanently, as the fur seems to get into every tiny gap.
I’m interested in what techniques and tools you use to effectively remove cat hair from the corners and gaps of a KALLAX shelf. Does anyone have experience with special brushes, vacuum cleaner attachments, or maybe home remedies that work particularly well in hard-to-reach places?
Also, I would like to know if there are preventive measures to stop cat hair from accumulating so much in these inaccessible corners.
I look forward to any helpful tips, as I’m looking for a simple and clean long-term solution without having to disassemble the shelf completely.
GiRoyce
5 Dec 2022 14:45
Hello, I wanted to add that regularly using a lint roller, especially around the shelves, is very effective.
Sometimes hair mainly accumulates along the edges. If you quickly run a lint roller over it daily, this prevents the hair from sticking to the wood and becoming stubborn in the corners.
I have also noticed that cat hair often clings to furniture due to static electricity. A slightly damp microfiber cloth, as mentioned before, works wonders in this case.
Ultimately, it is also important to groom the cat regularly – this can significantly reduce the amount of hair that collects in the KALLAX.
ju_ren
6 Dec 2022 08:53
Dampen rubber gloves, rub them over the corners – hair sticks to them, then collect it. This method works great and quickly for me.
O
olivernu
6 Dec 2022 09:16
I would also like to point out that when cleaning the KALLAX inside corners, caution is advised due to the material characteristics:
The edges are often coated only with melamine foil, which can be easily damaged by mechanical stress. Therefore, make sure that cleaning tools do not have sharp edges.
Soft, flexible brushes or vacuum nozzles made of soft plastic have proven to be practical.
I would use an electric steam cleaner very carefully, as moisture can cause the shelves to swell.
jatige
6 Dec 2022 12:34
Garry schrieb:
Electrostatic microfiber cloths also help because their charge causes hair to stick well.
That sounds interesting—could the effect of static electricity really play a role? Has anyone tried both regular microfiber cloths and specifically electrostatically charged cloths when it comes to removing hair from hard-to-reach corners?
retau schrieb:
Rubber glove method: Just put on gloves, dampen them a little, and then wipe the corners of the KALLAX.
I’ll try this tonight; it seems like a straightforward idea! How often do you clean the shelf to avoid thicker layers of pet hair?
Looking forward to more experiences!
Garry
6 Dec 2022 13:02
jatige schrieb:
Has anyone tried regular microfiber cloths and specifically electrostatically charged cloths?
Yes, electrostatically charged microfiber cloths are noticeably more effective at picking up cat hair than regular cloths. They attract the hair almost magnetically, especially when the hair is dry.
For cleaning shelves, I recommend not waiting until large accumulations of hair build up. Depending on the cat’s shedding, a thorough cleaning once a week is often sufficient.
PAREL
7 Dec 2022 07:41
Here is a brief guide for the rubber glove trick:
1. Use regular rubber gloves (e.g., household gloves).
2. Slightly dampen your hand with water—do not make it too wet, just moist.
3. Rub the dampened gloved hand over the corners and edges of the KALLAX.
This way, hairs stick very well to the glove surface and can be easily wiped off. It’s a great method because it also reaches particularly hard-to-access corners where vacuum cleaner attachments often fail.
After the gloves dry, you can easily wash and reuse them multiple times.
