ᐅ Issue with the Eaves Height (Rented Apartment in the Attic)
Created on: 11 Apr 2022 08:43
Marcel Gebaue
we are currently planning a multi-family house with 5 residential units for long-term rental.
The development plan is quite restrictive, and we have reached a dead end because of an issue with the eaves height. The building will be constructed by a general contractor, but unfortunately, the planners there are not very motivated to try many changes and approaches (although that is a separate matter).
The development plan stipulates that the total height must not exceed 9 meters (30 feet), and the eaves height may not exceed 6 meters (20 feet). The following is specified:
An allowable plinth height (top edge of the raw floor slab) of at least 30 cm (12 inches) and at most 50 cm (20 inches) above the street level specified in the site development plan. A visibly offset plinth may be up to 60 cm (24 inches) high. The defined maximum building height (9 meters (30 feet)) refers to the actual plinth height.
The maximum eaves height for two-story structures is 6 meters (20 feet) above the plinth height.
Is there any possible workaround or method to calculate the eaves height differently, perhaps setting it lower?
If we set the eaves height at 6 meters (20 feet) as required, the attic apartment, in my opinion, would no longer be habitable because the 2.30-meter (7 ft 7 in) and 2-meter (6 ft 7 in) headroom lines would move too far inward. The building already exceeds the permitted site coverage and floor area ratio. The lot is only 670 square meters (7,210 square feet) in size.
I have attached the section drawing and the attic apartment plan. The layout is currently only provisional and intended for illustration purposes.
I have also attached the relevant excerpt from the development plan.
Can anyone help us?
I would be very grateful for support.
Section through a multi-story house with basement, balconies, stairway, and pitched roof.
Attic floor plan with kitchen, living room, hallway, bathroom, bedroom, balcony, and dining area.
Excerpt from a building regulation document with highlighted sections regarding plinth height of 30–50 cm.
SoL
19 Apr 2022 07:18
And again, only with fragments (which honestly look like amateurish planning painted over by the general contractor); somehow Marcel/Dustin just doesn’t seem to make real progress ...
Yes, yes.
But his idea of making progress seems to be waiting for someone to tell him that everything works as is.
As long as no one does that, he looks for new forums and asks again with partial information...
