ᐅ Is underfloor heating practical in rooms smaller than 8 square meters?
Created on: 29 Jun 2012 11:25
Allegria
Allegria
29 Jun 2012 11:25
Hello dear forum members,
In your opinion, is it useful to install underfloor heating in rooms like the guest toilet and the utility room? According to the building specifications, these rooms would not be equipped with it since they are smaller than 8m² (86 sq ft).
Thank you and best regards
Allegria
€uro
29 Jun 2012 11:43
Allegria schrieb:
...do you think it makes sense to equip rooms like the guest bathroom and utility room with underfloor heating? According to the construction specifications, these rooms would not be fitted with underfloor heating because they are smaller than 8m² (86 square feet).
If underfloor heating is installed elsewhere with or without radiators, these rooms might risk insufficient heating ;-) The decisive factor is the room heating load = f(RT). On the other hand, increasing the system flow temperature might, depending on the heat source, be energetically inefficient :-) As is often the case, it seems there is no precise basic assessment and planning here! 😕
Allegria
30 Jun 2012 13:15
Thank you, then let's wait for the room heating loads.
