ᐅ Is installing underfloor heating in the basement worthwhile?
Created on: 6 Oct 2021 08:10
Pacc666
Hello
we are currently building a new semi-detached house
I am considering installing underfloor heating in the basement.
Our basement comes standard with conventional radiators under the stairs in the utility and storage rooms. As a special request, we will (red line) partition off this area as a separate room (of course with a door). The two lines at the back of the room will be ventilation slots to allow airflow since the other two rooms have windows.
The new room is intended as a pantry/storage room, and the storage room might be used as a workout room.
I have a few questions:
1: What do you think about installing underfloor heating throughout the entire basement? What are the advantages and disadvantages? The additional cost is 2700€.
2: In the underfloor heating package, the two rooms in the middle (hallway and newly partitioned room) will share a single heating circuit manifold, meaning the underfloor heating would be controlled by one thermostat and would heat both rooms. The underfloor heating would run beneath the new wall (a sand-lime brick wall).
My option would be, for an additional cost (amount unknown), to give the new room its own heating circuit, or to omit underfloor heating in that room altogether (which would of course reduce the extra cost of 2700€), or to have the hallway and new room share one heating circuit.
What would you recommend?
Floor plan of a building with entrance area, utility room, and storage space
Pacc666
9 Nov 2021 19:55
The radiators will be only about 30-40cm (12-16 inches) wide.
I am mainly concerned about the specifications
with thermostatic settings planned for basement purposes;
 a heating load calculation is not part of this offer; 
setting the location of the (enlarged) underfloor heating manifold;
 room thermostatic control.
What do the individual points mean?
RotorMotor
9 Nov 2021 19:57
Sounds very unspecific. I would suggest asking about the installation spacing and the number of circuits.
Deliverer
9 Nov 2021 20:02
Pacc666 schrieb:
The radiators will only be about 30-40cm (12-16 inches) wide
What does that mean?
I'm not the provider, so these are just my thoughts:
Pacc666 schrieb:
with thermostatic settings planned for the basement use;
Probably set a bit cooler. No extra cost.
It’s always helpful if an external company does this. Definitely have it done!
Pacc666 schrieb:
Setting up the location of the (enlarged) underfloor heating manifold;
To me, this sounds like meaningless filler text. The component just has to be installed, preferably in a vertical position. ;-)
Pacc666 schrieb:
 room thermostat control.
This has already been discussed. With a proper heating load calculation and balancing, you can be exempted from this. If not, make sure to request actuator valves that are fail-open, so the control can be disabled if needed.
OWLer9 Nov 2021 22:21
The heating circuit manifold costs between 100 and 300€ online.
The 17x2 pipe costs 160€ for 200m (656 feet). For 400m (1312 feet) to the basement, it costs over 300€.
If we assume the "plumbing prices" are twice as expensive as online, that amounts to 1200€ for materials and half a day of work. A maximum of 2000€, minus the cost of radiators.
Deliverer
9 Nov 2021 22:59
And excluding the costs for the mixing device. No idea what something like that costs. Or would the radiators have been operated at the same temperature?
Pacc666
10 Nov 2021 07:12
The radiators would be operated at 60 degrees Celsius (140°F).
What needs to be considered is that we will not have our own heating system but will be connected to a district heating network.
