ᐅ Is there modularity in the IKEA PLATSA components?
Created on: 5 Jan 2021 09:17
Blato55
Blato55
5 Jan 2021 09:17
I am currently looking more closely into the IKEA Platsa furniture and have a question regarding the modularity of the individual components, especially concerning the interchangeability and compatibility of the different parts.
Is there truly modularity in the IKEA Platsa pieces, meaning a systematic way to connect various elements such as carcasses, doors, drawers, and shelves flexibly, allowing for later modification or expansion?
Or are these rather fixed sets that may vary in size and design but do not offer genuine modular connections or replacement options?
I am particularly interested in whether individual parts can be easily replaced or redesigned later on without having to disassemble or repurchase the entire unit.
Does anyone have practical experience or information that could clarify the modularity of Platsa well?
barEsperan
5 Jan 2021 11:44
PLATSA is designed so that the basic components are usually interchangeable.
For example, carcasses, doors, and inserts can be replaced relatively easily.
However, the modules have fixed dimensions, so modularity in the sense of a building block system that works for all parts is limited.
Extensions are possible but always within the given dimensions and connection points.
GiRoyce
6 Jan 2021 14:05
Hello Blato55,
I’d like to respond in more detail to your thorough question about the modularity of the IKEA PLATSA components. PLATSA is indeed designed as a buildable and adaptable system.
Blato55 schrieb:
Is there really modularity with the IKEA PLATSA parts, meaning a systematic way to flexibly connect and later modify or expand different elements such as carcasses, doors, drawers, and shelves?
Basically, PLATSA offers several frame sizes that you can choose according to your room situation. For these frame sizes, there are matching doors, drawers, and interior fittings in correspondingly coordinated dimensions. These are modular, meaning you can add additional modules placed side by side later or modify existing elements by removing individual doors or shelves.
However, the modularity is not unlimited but tailored to the system and limited by the connection options of the elements. This also means that when adding parts later, you need to pay attention to the dimensions to ensure a proper fit.
Blato55 schrieb:
I’m especially interested in whether it’s possible to easily replace or redesign individual parts later without having to dismantle or completely repurchase the entire unit.
This works quite well in practice since doors, fronts, and shelves are attached with clips that are easy to release. Simple replacement is therefore possible—especially if you know the dimensions in advance and order or buy new parts separately.
In summary: PLATSA is modular within certain limits. It is less of an open-ended building block system like LEGO and more a furniture program equipped with a clear measurement grid and defined assembly and connection solutions, specifically designed for flexibility and expandability.
Hope this helps!
Gino38
7 Jan 2021 18:53
I would like to add an important aspect to the previous posts: The modularity of PLATSA works best in rooms with standardized dimensions and regarding its depth (which is typically 35 cm (14 inches) for PLATSA).
GiRoyce schrieb:
PLATSA is modular to a certain extent. It is less of a free-form building system like LEGO, and more a furniture system with a clear measurement grid and defined plug-in and connection solutions designed specifically for flexibility and expandability.
That is exactly the point: there is no universal compatibility of all parts with each other, but compatibility within the same categories and sizes. Additionally, the connectors and metal brackets provide stable support and allow for modular assembly that can be relatively easily altered if needed.
So if true modularity is important to you, when purchasing you should make sure to select the different modules according to a fixed plan that takes your room conditions into account. This way, you can ensure that your PLATSA remains flexible to use even after moving or redesigning.
