ᐅ Is there durable edge protection specifically designed for Kallax surfaces?
Created on: 10 Oct 2024 18:37
Mopoka
Hello everyone, I am currently considering whether there are durable edge protectors specifically designed for Kallax surfaces. Kallax shelves are known for their rather thin but sturdy panels, but the edges are often prone to wear or minor damage with frequent use, especially on the exposed shelf edges or when the furniture is moved frequently. I would like to know if anyone has practical experience with edge protection materials that fit well with the dimensions and surface texture of IKEA Kallax, without the protection wearing out quickly or looking unattractive. Ideally, the edge protection should be easy to install, long-lasting, and visually appealing, without the typical cheap-looking plastic. Are there any brands, materials, or methods you would recommend?
DUVIN schrieb:
I have had good success with self-adhesive PVC profiles. They are durable, relatively affordable, and easy to install without much effort.I can confirm that. Self-adhesive PVC profiles are convenient, but proper surface preparation is crucial. For Kallax, the edges must be thoroughly cleaned of grease, ideally with alcohol. Applying some pressure during installation significantly improves adhesion. If you keep this in mind, they are surprisingly durable.
Domau0 schrieb:
Regarding the question of durable materials, I would personally recommend aluminum or high-quality silicone.I agree with that. Aluminum is sturdy and visually appealing when well manufactured. However, it is also important to thoroughly clean the surface of the Kallax before installation to ensure a lasting bond.
In addition, manufacturers offer special edge protection profiles for furniture fronts that are UV-resistant and impact-resistant. It is important to make sure the profile is precisely designed for 16 mm (5/8 inch) panels. Even more important than the material is proper installation and maintenance. With simple aftercare, these protective profiles can last longer than expected.
