ᐅ Is there any feedback on Malm furniture repair kits?
Created on: 20 Aug 2018 18:23
Kenau55
Kenau55
20 Aug 2018 18:23
I recently bought a small repair kit for a Malm dresser because one of the drawers had become slightly loose. Before using the kit, I would like to know if anyone here has experience with the official Malm furniture repair kits from Ikea.
I am particularly interested in aspects such as:
- How easy is the repair kit to use, even without much DIY experience?
- From your experience, does the repair hold up long-term, or do the components come loose again after a relatively short time?
- Does the supplied material match the color of the Malm furniture reasonably well?
- Does the repair reliably fix the issue, or is it more of a cosmetic fix without lasting benefit?
I would appreciate any feedback based on practical experience, as I prefer not to invest the effort if it might not be worth it. Thanks in advance!
MANUEL
20 Aug 2018 19:07
I have used the repair kit. The application is very simple and usually fits well. The durability is good, and with normal use, there are no issues. The color match is acceptable but not perfect.
Rosaren
20 Aug 2018 21:45
Regarding Malm furniture repair kits: These kits are generally suitable for minor damage. I recommend the following approach:
First, it is important to prepare the repair surface thoroughly. Remove dust and loose wood chips, otherwise the adhesive will not bond properly.
The supplied materials usually match the appearance well, but you should pay close attention to the drying time of the repair compound to ensure a strong connection.
Based on experience with Malm dressers, I suggest considering reinforcement from the inside with wood glue or small brackets, especially for drawers under heavy use. Although the kit holds, additional supports should be used when the load is high.
Overall, these kits are a practical introduction to repairs, but for more significant damage, professional work should be considered.
miAlessio
21 Aug 2018 08:12
Hello Kenau55,
I would like to provide a structured overview of the Malm furniture repair kits, based on common questions and issues I have noticed:
1. Preparation: Be sure to thoroughly clean all surfaces and completely remove any sticky residues. Otherwise, the adhesive will not bond properly.
2. Step-by-step instructions:
a) Always mix the kit thoroughly to ensure an even color.
b) Apply evenly using a small spatula or wooden stick.
c) Let it dry with moisture and weight applied, as this is often crucial for durability.
3. Common mistakes:
- Insufficient drying time leads to poor results.
- Applying too much material and then scraping it off can leave unsightly edges.
4. Color tone: The kits are fairly close to the classic Malm colors, but small variations are normal. It is important that the finish dries matte to avoid shiny spots.
In summary, you can achieve very good results with the repair kit if you work carefully. It is not suitable for major structural damage but works well for small drawer chips or cracks.
If you have any questions about the application, I am happy to help.
CHARLES69
21 Aug 2018 13:56
I love these repair kits! 🙂 A few months ago, I used one to fix a drawer from my Malm dresser, and since then, everything has held up very firmly!
MANUEL schrieb:
The application is very easy and usually fits well.
That’s exactly right. Especially for people who don’t have much experience with wood repairs, these kits are perfect.
miAlessio schrieb:
Apply evenly with a small spatula or wooden stick.
At first, I didn’t pay much attention to that, so the surface was a bit uneven, but with some practice, it really turns out great!
So: hang in there, it’s not that difficult, and your Malm furniture will quickly look great again! 😉
hauklo
22 Aug 2018 09:38
An addition regarding durability and material quality:
The repair kits are designed specifically for the film surfaces typical of Malm. Permanent adhesion is generally good if the instructions are followed precisely. However, it should be noted that adhesive residues and possibly visible repair spots may remain noticeable on white surfaces upon close inspection.
In cases of structural damage, such as cracked or severely split wooden parts, the kits do not replace professional repair but offer a cosmetic solution with limited load-bearing capacity.
Therefore, assessing the extent of the damage before use is crucial. For minor touch-ups and small defects, the kits are suitable as a DIY solution.
In summary: With careful preparation and proper application, the repair kit is a sustainable option but does not substitute a genuine part replacement for more significant issues.
