ᐅ Is there a guide for converting IKEA BRIMNES dressers?
Created on: 2 Sep 2024 08:17
BENVIN
Is there a clear, detailed guide for modifying IKEA Brimnes dressers?
I am planning to modify my BRIMNES dressers to make them more functional, such as by adding shelves, removing or altering drawer fronts, or possibly installing additional compartments.
Does anyone know if IKEA or third parties provide modification guides that go beyond the standard assembly instructions? It would be helpful if these guides not only showed basic assembly but also included tips for alterations, alternative assembly methods, or structural adjustments.
Are there any experiences with modifying the BRIMNES series that can be shared here? If so, what should be paid special attention to? Thanks in advance!
nubar
3 Sep 2024 07:21
Good contributions so far. To clarify the thread further:
When modifying the Brimnes dresser, it is important to consider which function you want to change.
- For adding shelves: Pay attention to the height of the drawers and whether the side panels have enough depth.
- For removing drawers: The holes and mounting fixtures on the back panel may not be easy to remove, so visible holes will remain. This should be considered in advance.
If the goal is to modify the interior, you can work flexibly with slotted shelf supports and suitable dowels.
If you have some DIY experience, individual adjustments are possible, but a general guide is difficult to provide.
GiRoyce
3 Sep 2024 12:05
I would like to add the following:
Many users report that carefully removing the back panel and using custom-made wooden elements helps keep the dresser stable while allowing for new functions.
Another tip to ensure long-term usability: use screws with wall plugs or metal brackets, as this increases stability for modifications beyond the standard assembly.
There isn’t an official instruction manual, but with good preparation (measurements, material selection) and a careful approach, you can achieve a lot.
KAULIS
3 Sep 2024 15:27
SETHBLA schrieb:
No, an official modification guide does not exist.
That is correct.
In summary, modifying BRIMNES dressers is best done based on a self-created plan.
When doing so, you should:
- Always keep the dresser’s structural integrity in mind
- Respect material properties such as particleboard, surface coating, and fasteners
- Consider the possibility of avoiding permanent damage to fittings during the modification
Many modifications come from practical, DIY solutions since standardized instructions are not available. This allows for great creativity and a wide range of goals, but personal responsibility is required.
