ᐅ Is there a guide for remodeling IKEA Hemnes beds?
Created on: 20 Jul 2023 08:27
Bateresa45
Bateresa45
20 Jul 2023 08:27
I am considering modifying my IKEA Hemnes bed to make it more functional, for example by adding extra shelves or changing the side of the bed, possibly converting it into a daybed or another type of bed solution. Therefore, my question is: Is there a guide or an official/recommended method for modifying a Hemnes bed? I have some general assembly instructions, but nothing specifically about modification or alteration. I would appreciate any advice—especially regarding safety aspects that should be considered during the modification. Thank you very much!
Wesley
20 Jul 2023 09:14
Hey Bateresa45,
great question! Hemnes beds are really versatile, but officially IKEA doesn’t provide any specific conversion or modification instructions, since the furniture is designed to be assembled and used as is. However, I’ve heard from time to time that people have gotten creative—like adding extra shelves or removing and repurposing the headboard.
Maybe a DIY guide from the internet could help, or you could use the assembly instructions as a starting point for your modifications. Just be careful not to overtighten screws or compromise the bed’s stability. Safety first! 😉
Good luck, and let us know how it goes!
CHENFAR
20 Jul 2023 10:33
Regarding the question of whether there is an official guide for modifying IKEA Hemnes beds: No, IKEA does not publish specific modification instructions for this furniture series. The individual parts are designed for modular assembly, but only for the standard configuration.
If a modification is planned, it is advisable to study the existing assembly instructions carefully and consider the load-bearing capacity of the individual components. Changes to the bed frame or removal of parts should only be carried out with appropriate craftsmanship skills, as there is a risk of losing structural stability.
Additionally, it can be helpful to consult the DIY community, which often documents modifications in forums or blogs. Having a digital copy of the original assembly instructions is essential for such alterations.
Nabla64
21 Jul 2023 07:52
CHENFAR schrieb:
The individual parts are designed to be assembled modularly but for the standard construction.
Exactly, I'd like to add: Anyone attempting to modify Hemnes beds should proceed step by step and check all connections after the modification.
Here is a brief guide for general orientation:
- Carefully remove the standard side panels or headboard, keeping all screws.
- Check if the wooden panels need to be reinforced for stability (e.g., with cross braces).
- Additional elements like shelves can be attached on the inside using wood screws and brackets.
- An important detail: The original drill holes are positioned optimally for stability. New drill holes should be made carefully, preferably in less visible areas.
Common mistakes include overtightening screws, placing too much load on a single point, or ignoring the original structural design.
So: Always test step by step, avoid forcing parts, and preferably work with expertise or a helper.
Thierryzar
21 Jul 2023 08:14
I would like to add: Not an official IKEA instruction, but a clear recommendation:
- Do not damage original parts
- Check stability after modification
- Use only wood screws, no nails
- Consult a woodworking professional if unsure
pikin
22 Jul 2023 11:26
Bateresa45 schrieb:
Is there a guide or some kind of official/recommended method for converting a Hemnes bed?
There is no official step-by-step conversion guide from IKEA. For those who still want to modify the bed, these points are important:
- Hemnes beds are made of solid wood, which requires careful handling when drilling and altering.
- The main frame is structurally optimized for the standard assembly.
- Modifications that affect load-bearing components can significantly compromise safety.
- For additional features, it is better to add custom modules made from separate wood rather than altering the original parts.
In conclusion: Experimenting is possible, but making damage-free modifications must be planned carefully and done with an understanding of the structural integrity.
