ᐅ Is there an Ikea PLATSA community for creative DIY projects?
Created on: 1 Jan 2021 09:17
danbla35
Is there an IKEA Platsa community specifically for creative DIY projects?
I am currently focusing more on the PLATSA system from IKEA because its flexibility and modular design make it especially suitable for customized space solutions. I am wondering if, beyond the typical furnishing tips, there is an active community dedicated to creative modifications, adaptations, or even completely custom constructions based on PLATSA.
The purpose of my inquiry is to find places where people can exchange ideas, receive constructive feedback, and perhaps get instructions or tips for practical implementation beyond the official templates.
I would appreciate any suggestions on how and where to best connect—whether there are forums, groups, or platforms with this focus—and if anyone could share their own experiences on how creatively the system can be adapted without relying heavily on new materials.
danbla35 schrieb:
Has anyone got tips on how to increase stability by modifying the standard parts without having to do major rebuilds or use additional expensive materials?To improve stability, it is recommended to make better use of the rear cross braces and secure them to the wall at least in two places.
Although the original connectors of the Platsa system are generally load-bearing, for room dividers that are loaded on both sides, an additional wall mounting or support at the base is advisable.
You can also connect the modules together; this helps distribute the weight and enhances overall stability.
Avoid placing single modules free-standing without connecting the carcasses or adding brackets.
danbla35 schrieb:
As a concrete example: I’m considering building a combination of PLATSA cabinets and open shelves, which would then form a kind of room divider.This is an interesting project with several technical requirements.
In principle, I recommend approaching it in several steps:
- Step 1: Estimate the static loads. Books and plants create point loads that may be unevenly distributed.
- Step 2: PLATSA units that serve as a room divider should be assembled using sturdy connecting hardware – the IKEA original fittings help, but I would also add self-adhesive reinforcement brackets in suitable locations.
- Step 3: For open shelves, small metal brackets under the shelves are useful to stabilize against sagging.
- Step 4: Fixing to the wall or floor depending on the conditions and the room. Especially the combination of torsion resistance and stability is critical.
Regarding your question: Without major alterations, you can use simple battens (e.g., inside at the back panels), which you can otherwise bond with mounting adhesive. This greatly increases the overall rigidity.
If you like, I can write a small step-by-step guide on how to implement this, depending on your room layout.
Surela schrieb:
If you want, I could write you a small guide on how to implement this step-by-step, depending on how your room looks.I would really appreciate that!
My room has a rectangular floor plan, approximately 3.5m x 4m (11.5ft x 13ft), with a wooden floor and rough plaster walls. It is the area used as an open office. Since the cabinets and shelves don’t touch walls on all sides, stability is my main concern.
If the guide could also cover how to connect PLATSA modules together, as well as tips for integrating them with open wooden shelves, that would be perfect.
