ᐅ Is there a simple way to protect Ikea BESTA furniture from water stains?
Created on: 4 Dec 2024 09:17
bjarne30Hello everyone,
Some time ago, I bought a few IKEA Besta cabinets and sideboards, but I’m not entirely satisfied with the surface when it comes to water stains. Especially when glasses or vases are placed directly on the surfaces without coasters, unsightly rings or water marks quickly appear, which are hard to remove. My question:
Is there a simple and practical way to effectively protect the surfaces of IKEA Besta furniture from water stains without significantly changing the design or feel? I’m thinking of something like a transparent protective film or an easy-to-apply sealant that lasts as long as possible.
What should be considered if you don’t want to use professional application methods? Do you have experience with certain products or straightforward DIY solutions that really help here?
I would appreciate any tips and recommendations!
Good approach to tackle the topic thoroughly!
Furniture from the BESTA series typically consists of coated wood particle boards with a smooth, often melamine resin-like surface. These surfaces are generally quite resistant to moisture, but water stains often occur if moisture remains for too long or if mineral deposits from water leave the appearance of discoloration.
If you are looking for a simple method, there are several options, each with its pros and cons. Here is a brief overview:
- Transparent protective films: There are special furniture films or clear lacquer sprays that are almost invisible. The downside is that they can become uneven if applied improperly or may peel off over time.
- Micro-sealings with waxes or oils: Some furniture care products based on wax create a thin protective layer that repels water. However, this can slightly roughen or change the surface.
- Clear lacquer based on acrylic or polyurethane: Very effective, but requires careful preparation: thoroughly clean the furniture, lightly sand it, and then apply. Although this is a professional application, it can be done yourself with some patience and precision.
- Simpler everyday solutions: For example, consistently using coasters or placing a thin glass plate on top to protect the surface discreetly.
I would also like to know how heavy the use is: Does liquid frequently remain on the surface, or is it more occasional? Are you looking mainly for short-term protection against condensation and drops, or for long-term preservation of the surface?
This way, we can identify the best solution.
Dilen schrieb:
I would also like to know how frequent the exposure is: Do you often have liquid on the surface, or is it more occasional?Good question! I have similar furniture at home, and for us, this usually only happens when you quickly put down a glass or when a flower vase leaks water – so not constantly, but every now and then. 😅
What I’ve found works for me is a small, thin plastic or silicone mat. You barely notice it, it doesn’t really change the look, and it effectively protects against those annoying stains.
If you’re looking for a truly invisible solution, this might not be ideal, but I think it’s better to use little helpers like this than to have to deal with difficult furniture polishing later on.
That said, I’m curious if anyone here has ever tried a varnish or similar coating? Would that really affect the nice surface appearance that much? Or is there something that remains nearly invisible while still offering protection?
bjarne30 schrieb:
Is there a simple, practical way to effectively protect the surfaces of IKEA BESTA furniture from water stains without significantly changing the design or feel?Hello Bjarne,
I have looked into protecting IKEA furniture and can give you a step-by-step guide on how to achieve a durable sealant yourself with reasonable effort, while largely preserving the appearance:
1. Cleaning: First, remove all dirt with a mild, grease-free furniture cleaner.
2. Light sanding: Using very fine sandpaper (about 320 grit), lightly sand the surface so the sealer adheres better.
3. Choosing a sealer: A matte or satin-clear water-based varnish (polyurethane or acrylic) works best. It changes the look only minimally.
4. Application: Apply thin coats evenly with a good brush or foam roller. Then let it dry thoroughly.
5. Intermediate sanding: After the first coat, sand very lightly again and remove dust.
6. Second coat: Apply and let dry.
This method is actually doable for non-professionals if you take your time. The result is a robust, water-repellent layer that significantly reduces water stains. Aesthetically, the surface remains very close to the original.
Tips:
- Good ventilation during application is important.
- Test first on an inconspicuous spot.
- Using coasters is still the best prevention.
juMira46 schrieb:
Has anyone here tried applying a varnish layer or something like that?Yes, and I can confirm: if you apply the varnish thinly, it is hardly noticeable and provides very good protection.
I hope this helps you!
