ᐅ Is there a simple way to fix Ikea BESTA doors that constantly rattle?
Created on: 24 Jun 2024 18:37
Egmont
Egmont
24 Jun 2024 18:37
I recently got an Ikea Besta sideboard with the typical doors, and unfortunately, these doors constantly make rattling noises even with a light bump or gentle closing. The sounds are quite annoying, especially in the living room, which is otherwise quite quiet. I assume the rattling comes from the hinges, door stops, or guides since the doors fit well and don’t seem loose, but obviously something is not set up optimally or a damping element is missing.
Therefore, I would like to ask: Is there a simple, perhaps user-tested and proven method to permanently fix the chronic rattling of the Ikea BESTA doors without completely removing the door or making major modifications? I’m particularly interested in solutions that require little tooling, avoid the purchase of additional parts, and don’t involve complicated adjustments.
I would appreciate your experiences, tips, or possible causes!
gregto
24 Jun 2024 19:29
Hello Egmont,
I am familiar with your issue of rattling BESTA doors – this is a relatively common problem with IKEA furniture that uses simple hinges and thin doors.
There are a few proven methods:
- First, check if the hinges are properly adjusted. Often, tightening the screws on the hinges slightly and making small adjustments to the door positions helps.
- A frequent cause of rattling is missing dampers. Although IKEA usually doesn’t provide specific damping pads for BESTA, you can apply small self-adhesive felt pads or silicone bumpers to the inside of the doors or the edges of the cabinet. These absorb the impact and prevent rattling.
- It also sometimes helps to replace or adjust the door seals (if present). The rubber buffers that cushion the closing action can wear out over time.
- If you open and close the doors regularly, dust or dirt can build up in the hinges, which can increase the rattling noise. A thorough cleaning and light lubrication with a suitable lubricant (e.g., silicone spray) won’t hurt.
I would start with these simple steps before doing more extensive modifications. If you like, I can provide more detailed tips on adjusting the hinges. Good luck!
flo-Theres
25 Jun 2024 07:42
I would like to add something to the points already mentioned. It is important to approach the problem systematically:
- First, check whether the rattling comes from the hinges themselves or possibly from the door panel hitting the cabinet frame.
- For the hinges: Often, the clips that attach them to the back panel are slightly worn or not completely tight. This leads to minimal movements, and since the lever point is far out, it amplifies the rattling noise.
- A proven trick is to stick small thin cardboard pieces or double-sided tape under the hinge plate. This fills the gap and reduces the wobbling.
- On the door stop side, where the door rests against the cabinet, self-adhesive foam strips or sponge pads are effective. These help dampen vibrations when closing.
- Some users have also found it helpful to replace the door seal with a slightly thicker one from a hardware store and ensure the door fits more snugly along the edges without sticking.
- Finally, keep in mind that with BESTA systems, the doors are relatively lightweight—therefore, the noises are unfortunately sometimes a typical issue and can often only be reduced with such simple aids.
In conclusion: The rattling can usually be significantly reduced by optimizing the contact points and buffers with a few small, soft materials.
Fitigu
25 Jun 2024 12:18
I’ll summarize this in a structured way and add some technical details that are often overlooked:
- The cause of rattling in Ikea BESTA doors is usually mechanical resonance, triggered by minimal movements at the hinges or door stops.
- The hinge itself is a simple folding mechanism with a plastic plate that forms the contact surface and may show signs of wear. This creates play (looseness).
- A straightforward method for permanent elimination:
- Completely loosen the hinge screws, slightly reposition the door, and then evenly tighten them again to minimize play.
- Apply self-adhesive foam or felt pads along the inner edges of the doors, especially where the doors meet the cabinet body, as this effectively absorbs vibrations.
- Use a small amount of silicone spray or Teflon spray on the hinge joints to reduce rolling friction and thus minimize micro-vibrations.
- Important: Do not use oil, as it attracts dirt and degrades function over time.
- If rattling occurs mainly when the doors are closed firmly, attaching small pieces of double-sided tape or thin plastic strips directly to the hinges can help restrict free play.
- These measures are easy to implement, do not require removing the doors, and can be done with common materials.
In summary: From a technical perspective, the most effective way to permanently fix chronic rattling of Ikea BESTA doors is a combination of adjustment, damping through soft pads, and lubrication of the hinges.
